Can't reassign weight measurements from my Aria 2
ANSWERED
Hey Guys - we had a situation where our scales for some reason started to think my wife was me.  I've since found that back in November, the scales took one of my measurements and assigned it to her for a few days.. and that got it out of order.  Now I want to go back to those weights and assign them to me, but it appears you can't reassign weights older than 30 days.  There's a 10kg difference between us both, so I'm keen to get this sorted.  The web interface does not permit it, neither does the iOS App.  Any clues?
1 BEST ANSWER
Accepted Solutions
@sbsfaq  @lindahicksaz   I looked over the logs for me and my husband and, yep, it sure looks like you can't go past 30 days on the recent weight ins.
I have an easy solution and a tedious solution.  The easy solution is to go through your weight logs -- you can go way back in the weight log by tapping on the weight tile -- and delete any incorrect weight and forget about it.  The tedious solution is to:
  1. Manually make a note of every incorrect weight.
  2. Delete the incorrect weights.
  3. Manually log every weight to the correct user.  When you use the Log Weight option on the app, you can tap on the Date and assign it to a different date.
I vote for the easy solution.
Laurie | Maryland
1 REPLY 1
Laurie | Maryland
