Change WifFI network on Aria
How do I change the WIFI network my Aria is connected to? I can not see any option to edit or change that.
8 REPLIES 8
Please see this article:  changing wifi network
Thx Patruns!!
Note to FitBit staff... you can edit the name of a scale with a simple edit button... It should be easy to edit wifi from the device menu also, you need to creat an easy link to this article to edit the Wifi network.  It should NOT be necessary for me to do a search on the community forum to learn how to edit the wifi.
You should also pay a consulting fee to Patruns for doing your work for you!
I was thinking the EXACT same thing. This should not be a difficult task.
@SEAustin @Nillemont It's great to see you both in the Community! I really appreciate your feedback and comments since this helps us to keep improving and adding new features so the Fitbit experience can be best.
If you have ideas regarding the network edit option, please submit your request in our Feature Suggestions board and people with the same idea can vote for it.
@SunsetRunner As always, your help and contribution is greatly appreciated!
See you later my friends! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
How do I change wifi networks
@JaniceSawade Welcome to our Fitbit Community! Regarding your question, I'd like you to follow the steps that are listed in this help article. Hope this helps.
Let me know if you need further assistance! Smiley Happy
These instructions appear to set up the scale as if it's a new device. Will I lose the weigh-in I did this morning?
@leorising Regarding your question, I recommend you to sync your device before so your weigh ins can be saved in your Dashboard and the Fitbit platform.
