01-31-2014
00:03
05:24
JuanJoFitbit
01-31-2014
00:03
05:24
JuanJoFitbit
I love my Aria, don't get me wrong. But WHY should changing batteries be such a complete pain in the a**? What should be a simple user task requires the whole charade of trying to reconnect to the network, which usually means going to the website on another device to figure out how to do it, it usually takes me about 15 minutes all up. Changing the actual batteries takes 10 seconds. It's not trivial. It is a very poor user experience that surely must have a simpler solution.
Moderator edit: Updated subject for clarity.
09-11-2018 08:23
09-11-2018 08:23
@Darla499 Thank you for joining us in this thread! I'm sorry to hear that the issue that your Aria is experiencing could not be resolved. I totally understand your frustration about this and thank you for your feedback. Please check out this page which explains more information about the warranty policies.
@RichardMW I truly appreciate your feedback and comments about the Aria as well. Your information will be sent to the rest of our team.
03-10-2019 07:35
03-10-2019 07:35
...and meanwhile it’s now 5 years later and the same issues exist. This is my first and last Aria!
03-13-2019 06:34
03-13-2019 06:34
@JeaniePro Thank you for joining our Fitbit forums! I'm sorry for the late response. However, I'm sorry about the experience you had with your Aria scale. I totally understand how you feel and your feedback is appreciated.
03-16-2019 21:39
03-16-2019 21:39
I don't think that the Fitbit company really listens to their customers. You have to pay so much for the scale that you expect it to last but of course it usually dies just after the warranty expires. They pretend to provide support but just tell you to try this and that so that you can get frustrated and then they tell you that they understand how you feel!
03-17-2019 08:32
03-17-2019 08:32
I first posted in May of 2015 to try and help others as to how to see the battery change coming, and how easy it is to change. I still have the scale, it still works, and changing the batteries is still easy. I am not a brain surgeon either. And I probably won't buy another because I expect it to last forever. I don't get the problem folks. I get emails to change the batteries; it warns me that the batteries are low, there is an icon on my phone, and when I change the batteries, the scale is put back in place, and works immediately. I am not an employee, just relating my experience, which is that it is no problem still, nearly 4 years later
03-17-2019 12:24
03-17-2019 12:24
It's great that you got one of the scales that works well and that you don't have to understand the challenges most of us face. However, changing batteries in my scale is a massive challenge and it has to be set up several times to get it to work again. This last time I got the strongest, longest lasting batteries I could find so that I don't have to do it again for a very long time. None of the tips or hints work on my scale, I have to just keep resetting it until it just catches on the 8th or 15th try.
03-17-2019 12:52
03-17-2019 12:52
03-17-2019 13:33
03-17-2019 13:33
03-17-2019 13:38
03-17-2019 13:38
03-20-2019 09:38 - edited 03-20-2019 09:39
CROUCHERG, It's all well and good that you don't have any issues changing batteries, but as you can see from the large number of posts from those of us who found it difficult, or impossible, to reconnect to wifi after changing batteries, this Forum is intended to ask Fitbit for better instructions.
Denigrating those of us who have had problems is unacceptable.
03-20-2019
11:39
06:07
JuanJoFitbit
03-20-2019
11:39
06:07
JuanJoFitbit
This is classic internet. 'all the posts' Imagine what % you are of all the folks that own scales. Also; the only reason I post is to be helpful. The rest of the happy scale owners have no reason to reply.
Also: I posted to he HELPFUL, not to deride anyone.
Moderator edit: merged reply
03-20-2019 11:51 - last edited on 01-30-2020 12:34 by LiliyaFitbit
Not sure how your post was helpful. You only indicated that the scale worked perfectly for you. The rest of the posts are looking for Fitbit to provide actual instructions that work.
03-20-2019
12:14
06:08
JuanJoFitbit
03-20-2019
12:14
06:08
JuanJoFitbit
You are right, about this post, but I posted other times, explaining how one can see on the fitbit site and get notifications, and how I changed the batteries and had no issue. But you are correct. This time, other than being a cheerleader for fitbit, I was perhaps not so helpful.
From a previous post: "You can look on your phone or pc and the aria appears with a battery level indicator. Also; I get an email when it is low."
I believe when you change the batteries when they are low, but not dead yet, then the scale continues to work.
I do agree that fitbit could be more helpful on the instructions.
03-20-2019 12:45
03-20-2019 12:45
Yes, I can see when they are low, but changing them at low instead of dead makes no difference. Taking out one battery at a time and replacing them that way makes no difference for my scale. I think there was a big issue that made it through quality control and fitbit hasn't really been helpful at all with solutions. This is not unusual for them, just look at the issues with the Charge 3 and the 'be patient' message they keep giving. They have no intention of fixing the Aria.
03-20-2019 12:48
03-20-2019 12:48
03-20-2019 12:55
03-20-2019 12:55
Agreed. They appear to be completely absent on their own forum.
03-20-2019 13:22 - last edited on 01-30-2020 12:35 by LiliyaFitbit
Thank you for recognizing that 🙂
Just so you know, i talk up the Aria scale all the time...i just dread the next time i have to change the batteries.
03-20-2019 14:17
03-20-2019 14:17
😉 I must be living right (ha ha)
03-20-2019 15:06
03-20-2019 15:06
05-28-2019 14:21
05-28-2019 14:21
It takes much longer than 15 mins, I've been trying for hours, says it's successful, then says step on step off, thinking, then error, then nothing, doesn't even work as a scale. It is extremely annoying, Time Fitbit fixes the problem!
