01-12-2019
13:37
08:45
01-12-2019
13:37
08:45
I like so many others I'm sure get those annoying feet smudges. My question is can I use baby wipes to clean the the glass surface off? I've used my box of Lens wipes that are for all surfaces but it doesn't stay damp long enough to get it off (Plus they are to small.). While I love my feet I don't think I need to see my foot size smudged on my scale.
Moderator edit: format
01-12-2019 13:54 - edited 01-12-2019 14:08
@Newfitkitty take look at this link on cleaning it may help.. All I use on mine is a damp cloth and a dry one to dry it off.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer01-14-2019 05:46
01-14-2019 05:46
@Newfitkitty It's great to see you in our Fitbit Community! I would like to follow up and would like to know if the great tips that shared @Tony.r helped you.
Looking forward to your response! ![]()
