06-13-2018
11:48
14:53
06-13-2018
11:48
14:53
Hi everyone! It has come to our attention that some users are experiencing issues with syncing/setting up Aria scales with Comcast/Xfinity routers and we are currently reviewing.
There is a workaround that has helped most users. For this, follow the instructions below:
Thank you all for your patience. Any update available, I'll make sure to share it in this thread.
03-07-2019
04:09
07:04
JuanJoFitbit
03-07-2019
04:09
07:04
JuanJoFitbit
There does not seem to be a fix! I sold my Aria and bought a RENPHO off Amazon for like $30 I am way happier with the RENPHO
Get a RENPHO scale you will be so much happier and save yourself mountains if stress
Get Outlook for iOS
Moderator edit: merged reply
Best Answer03-07-2019 04:33
03-07-2019 04:33
03-07-2019
06:15
07:06
JuanJoFitbit
03-07-2019
06:15
07:06
JuanJoFitbit
I’ve still using my Fitbit tracker but only until I get my Apple Watch. I dumped the most expensive paperweight ever and got a Qardio scale. It’s a lil pricey but zero regrets! Also, it is TOTALLY consistent, which my Aria never was. It also synchs with MyFitnessPal which will then synch with your Fitbit tracking app. A shame because I LOVE Fitbit app but the products are garbage. Aria 2 will have similar issues very soon. STAY FAR AWAY!! Crazy they ignore us because if you bought an Aria, chances are you’ve bought multiple Fitbit products. I’ve had 5 different trackers from them and the scale and NO MORE FROM ME based on how they handled the aria issue. An apology and a reduced price aria / offer probably would have kept me in the beginning of this debacle that started over a year ago for me!
Best Answer03-07-2019 07:33 - last edited on 02-03-2020 18:37 by LiliyaFitbit
Still having trouble as well. Fitbit customer service is not able to assist and are saying it’s because I have service with Comcast and they made an incompatible upgrade. Totally frustrated as well. I will never buy another expensive worthless scale from them again. Total waste of money and time
Sent from iPhone
03-07-2019 08:19
03-07-2019 08:19
03-07-2019 09:50
03-23-2019 09:33
03-23-2019 09:33
Comcast WiFi router
xfinity dual band WiFi 802.11ac xb3
aria
Best Answer03-23-2019 11:03
03-23-2019 11:03
Best Answer04-05-2019 18:26
04-05-2019 18:26
I've tried these steps and it's still not connecting - it looks like this is an older post, has a new solution been found?
My 2.4 network is set to the 802.11 b,g,n with WPA2 security.
04-14-2019 11:50
04-14-2019 11:50
This did not work for me. I cannot get the scale to read beyond the "Setup Active" message. Been at it for an hour. So frustrating
04-14-2019 19:04
04-14-2019 19:04
04-24-2019 13:56
04-24-2019 13:56
A recent update by Comcast, and now you can't even change the b/g/n option anymore.
So, I bought an inexpensive wireless router (less than $20 on Amazon) on set it up in WISP mode. It uses WiFi to connect to my Comcast modem, and exposes a whole new Wifi network. I then connected the Aria scale to the new WiFi network, and all works perfectly. The router I bought was WAVLINK 300Mbps Wi-Fi Router. It was fairly simple to set up the new router (you can also connect it directly to the Comcast modem with a provided network cable, instead of making a WiFi connection, but the way I set it up, you just plug into an outlet somewhere, connect to it with your phone, and tell it to use WISP mode. It lets you select a Wifi network and enter a password, then it does its magic. Of course, after it finishes, the new network is not secured, so you need to connect to the new router again and configure a password for the new WiFi network.) The SSID of the new WiFi network will be something like WAVLINK_1234 (no spaces, so it works with the Aria scale.)
So, FWIW, a $20 solution to get a $100 scale working.
04-24-2019 16:48
04-24-2019 16:48
Good for you, @joeamato59 ! Thanks for putting your energies into a creative, affordable, simple solution (and sharing it with this thread) rather than complaining, blaming and vilifying Comcast and Fitbit because a 10-year-old piece of hardware is outdated. My solution was similar, except I used an old Linksys router that was in the spare parts box in my garage. Works perfectly and I didn't spend a cent. Heaven knows, there's enough electronic waste in the landfills. Reuse, re-purpose I say!
04-25-2019 03:54
04-25-2019 03:54
05-04-2019
18:16
07:08
JuanJoFitbit
05-04-2019
18:16
07:08
JuanJoFitbit
I called in for support today and spoke to Kevin, he forwarded me a copy of this post but it did not work.
I have been on the phone support with this issue before and it still does not work, something is wrong and I have tried the work around of cleaning the contacts and my scale still is unusable. Please let me know if there are any other ways before I have to go out and buy another product that is not FitBit.
I have used this workaround many times, always successful. However, Comcast has now disabled the option for the user to change the mode from b/g/n to g/n then back to b/g/n. I confirmed this with Tier 2 support from Xfinity 12/15/18. Now, you will have to call an Xfinity rep to do this for you. I don't know if this is an Xfinity wide restriction or a regional one. FYI I am in the Philadelphia market
Best Answer05-11-2019 09:07
05-11-2019 09:07
Best Answer05-11-2019 09:11
05-11-2019 09:11
Hello. Did this work long term? Can I get your assistance? I bought another router, but I'm not having any success. Thinking i should have spent money on a scale now.
Best Answer05-12-2019 05:40
05-12-2019 05:40
Best Answer05-12-2019 05:44 - last edited on 02-03-2020 18:31 by LiliyaFitbit
That’s exactly what I did. Bought a different scale, and swore off Fitbit products in the future. Was going to buy my mom the Fitbit scale for Mother’s Day, but got her a different one instead.
Sent from my iPhone
05-12-2019 06:01
05-12-2019 06:01
