06-13-2018
11:48
14:53
06-13-2018
11:48
14:53
Hi everyone! It has come to our attention that some users are experiencing issues with syncing/setting up Aria scales with Comcast/Xfinity routers and we are currently reviewing.
There is a workaround that has helped most users. For this, follow the instructions below:
Thank you all for your patience. Any update available, I'll make sure to share it in this thread.
06-04-2020 16:00
06-04-2020 16:00
Amen to this @sbfurlan4. Don't even try to connect your Aria scale to the Xfinity gateway - you'll drive yourself nuts.
The only thing that I've been able to make work is to plug an old router that supports wireless B into one of the ports on the Xfinity gateway, set it up as a separate network, then connect the Aria to that network.
Best Answer06-06-2020 08:52
06-06-2020 08:52
Definitely outdated and this no longer works.
Selecting " b/g/n" is not an option! Need another method to connect the scale!!
All because I switched ISPs I no longer have the tracking ability of the scale.
Not happy as I have wasted 2 hours trying to follow the instuctions provided.
Best Answer06-08-2020 18:57
06-08-2020 18:57
I'm sorry, there is no "Additional Setup" on the link that you send. I've been fighting with this stupid scale for two hours now, and ready to just throw it out and go with Apple
06-09-2020 04:20
06-09-2020 04:20
06-09-2020 05:10 - last edited on 06-15-2020 18:10 by LiliyaFitbit
I switched to Renpho too and am way happier. It syncs with all my devices, much less expensive and works every time Plus Super easy setup
Sent from iPhone
07-04-2020 10:18
07-04-2020 10:18
This “work around” did not work for me. Did it work for anyone else??
Best Answer07-05-2020 09:04
07-05-2020 09:04
Hi,
Is there an update to this workaround with XFi WiFi? My Aria will not connect to the internet and the option to select 2.4 frequency is no longer available. Thanks
Best Answer07-05-2020 09:20 - last edited on 01-01-2021 09:59 by LiliyaFitbit
Unfortunately no one has figured out a way to work around it unless you purchase your own router/modem and do not rent the one from Comcast
My son bought a router from Netgear to replace the one from Comcast and his Aria is now working. I checked with him again today.
Your other option is to by a different brand of scale like Renpho which may be a cheaper option Depending on if you compare initial or long term investment
Sent from iPhone
07-05-2020 11:11
07-05-2020 11:11
@sbfurlan4 - I've found that you can set up a second router that works with the Aria scale, and you don't need to dump the Comcast router/gateway! You can have both. I did it, it works for me, and it's easy.
All you need to do is plug another router (almost any cheap router will work...even a $5 one from the thrift store) into one of the ports on the Comcast gateway and configure it as a new wifi network...call it fitbitscale or something like that...and connect your Aria to it. Then you've still got the comcast connection for your main computer, can use their XFi app, etc etc. - and be able to use your scale too.
07-05-2020 11:41
07-05-2020 11:41
For everyone still replying to this thread:
There is no work around. The scale uses 802.11b. All newer router do not support 802.11b. So if you have an ac/WiFi 6 router you will never get this scale to connect. NEVER.
What you can do as others have said is find an old 802.11 b/g/n router. Set it up as an AP and use that for your scale. But I’m betting if you are on this thread, you don’t have the technical skills to do that.
Why Fitbit used a WiFi standard that was introduced in 1999 on their scale is crazy.
07-05-2020 22:39 - edited 07-05-2020 22:45
Not true, you can setup an old router that supports the 802.11b protocol and the Aria scale can use this parallel wi-fi setup. Just plug the old (802.11b) router into the second port on the Xfinity router. There are a number of folks here that have used this workaround successfully.
On the other hand save yourself some pain setting up a parallel network and order a Rehpho on Amazon. Think you'll be much happier.
07-06-2020 04:36
07-06-2020 04:36
I have gotten rid of my old ARIA scale. I want to be removed from this community.
07-15-2020 06:56
07-15-2020 06:56
DO NOT FOLLOW THESE INSTRUCTIONS unless you want every device in your house EXCEPT the Aria to be disconnected, want to spend hours on the phone with Comcast trying to fix it, and want to narrowly escape filing for divorce because your husband is so angry.
09-15-2020 03:04
09-15-2020 03:04
Cannot connect my Fitbit Arial to Wifi, model: FB201W
Serial No: SB35013QVJEYU701
Is this model now completely obsolete? Is there a way to connect a scale again on WIFI?
Thank you
Best Answer12-20-2020 12:35
12-20-2020 12:35
I do not have the option of b/g/n. Only g/n or n. Xfinity cannot add b as an option tried that. They suggested Port Forwarding, but I would need a port range number for the aria. Anyone have success with that or know what the number is?
Best Answer12-20-2020 12:39
12-20-2020 12:39
Usually G is backwards compatible with B. There's some other reason Comcast routers won't work with it. A G Linksys router works fine.
Best Answer12-25-2020 12:42
12-25-2020 12:42
I was having the same problem with the area and I replaced it with inspire to and the same thing is happening it’s not connecting and just now and told me can’t find the device and that was after resetting the connection I don’t know what to do any suggestions
Best Answer12-29-2020 12:06
12-29-2020 12:06
I can’t get to the post you referenced. When I click on it, it tells me I don’t have permission
Best Answer12-31-2020 09:04
12-31-2020 09:04
Hello, I have the xfinity gateway with pods and it does not give me the ability to change the 2.4 frequency to b/g/n as it states the system not automatically picks the frequency to support the household needs. Is there another way?
I am working with xfinity also but am unsure of the solution yet. Does anyone know if the newer sales are flexible enough to connect to what ever frequency is being used? I don’t want to buy a new one and have the same issue.
Jim
Best Answer12-31-2020 09:10
12-31-2020 09:10
Kate a lot of the post are 2 years old. Is there a resolution? Mine just stopped connecting and I have tried all the solutions suggested....
