Does the Aria display accurate and consistent readings?
I have purchased several digital scales from WW.  I had to return them because they giving different reading even with minutes of each time I get on the scale.  The scale is made for WW by Conair.  I was wondering does the Aria give consistent readings or do they fluctuate?
Film-Doc
1 REPLY 1
My Aria 2 seems to be consistent but I can't comment on whether it is accurate.
There is a comment in the manual that is relevant to your question:
"If your Aria 2 is picked up and moved between measurements, or stored
sideways against a wall when not in use, the scale will go through a calibration
process the next time it is used for weighing. Up to two consecutive weigh-ins
will then be required before your scale is recalibrated and again displays
consistently accurate measurements. "
taken from: https://staticcs.fitbit.com/content/assets/help/manuals/manual_aria_2_en_US.pdf
