12-05-2017
17:11
08:45
12-05-2017
17:11
08:45
My new Aria 2 appeared to work one time. Since then I have consistently gotten an error message. I paired it to WiFi and internet. Have removed batteries and reinserted. On hard surfaces. Get "ERROR" then "1" I hate to send it back right away
12-05-2017 18:19
12-05-2017 18:19
I just opened up my Aria 2 which came yesterday, I set it up today, and got the same error message that you did. What does this error code mean?
Best Answer12-06-2017 10:30
12-06-2017 10:30
@TrebN28, @RonM Thanks for reaching out, glad to see you here in the Community. Check out my post here for information on Error 1, basically, it means you have been on the scale too long, when you see the feet move backward you should step off the scale. Hope this helps!
Actively managing your weight? Find accountability buddies on the Manage Weight board
Best Answer01-12-2019 20:37
01-12-2019 20:37
Did you ever get your Aria 2 to work? I am having the same problem. Set up WiFi -
set up on iPhone app - Stepped on scale and
waited - waited - then finally ERROR “1”.
7416-Mom3
Best Answer02-20-2019 07:22
02-20-2019 07:22
@7416-Mom3 It's great to see you in our Fitbit Community! I'm sorry for the late response. However, I would like to follow up on the issue you are experiencing and would like to know if the issue persists or if you managed to fix it.
In the meantime, please check out this help article, which explains more information about this error.
Looking forward to your response! ![]()
