04-22-2024 23:28
04-22-2024 23:28
Hi,
I bought Fitbit Aria 2 at the date 08/03/19. It worked well until September 2021. After that, fat percentage is never calculated. I am not close to my scale, so I didn't see it until now that I am trying to lose weight again.
I have already restarted and re-calibrated the scale by taking out the batteries for 15 seconds and put them back in. Then I weigh myselft 5 times in a row, as I could see on the internet, but the fat percentage is still not appearing.
I placed in on a plane surface.
I checked my data is OK online, weight, height, and birthday.
At the end, it will always display --%.
Is there anything to do to fix it ?
Thanks for your help
Best Answer04-23-2024 11:05
04-23-2024 11:05
Assume you know have to be in bare feet. And make sure it is Aria 2, not Aria Air. Look at what it is called in phone app.
Best Answer04-23-2024 14:16
04-23-2024 14:16
I'm having similar issues. I got the Aira 2 yesterday (Gifted to me). and the body fat % seems to be way off. I used "Lean mode" aswell. Its saying im +32% bodyfat which isn't possible I'm probably somewhere from 19%-26%. I put in fresh batteries and did a factory reset on the scale. Also I have another digital scale and It seems like the Aira scale is showing around 1 pound or so less weight than my other digital scale which claims to have 99% accuracy.
Is anyone else experiencing the same issues with Aira 2? I'm using it with my Fitbit Charge 6. Also I highly question the calorie burn on my fitbit charge 6. I think it's over-estimating calories burned by a lot.
