04-19-2023
10:52
04:33
04-19-2023
10:52
04:33
I have had an un-opened FitBit Aria 2 scale that has been laying in it's box for almost 5 years.
(i didn't know i had this in it's box for all these years, and just found it today).
After setting it up everything appears to be working fine, but it's on an old Firmware (23.21.6.0)
I have also noticed that this scale has been discontinued.
So my question is, would i be able to receive the latest Firmware update (23.27.2.0) still?
Even though it's been discontinued?
05-11-2023 05:58
05-11-2023 05:58
After nearly 3 weeks the scale finally got updated to the latest Firmware (23.27.2.0).
Not sure why it took so long, but it finally updated itself today.
I can confirm that the latest update for this scale is 23.27.2.0 for all countries (and not just for Japan).
Best Answer04-19-2023 18:24
04-19-2023 18:24
Hi @SuperConker ,
My understanding is even though the scale is discontinued, it will still be supported. I would update the firmware to the latest version I can.
one cruise ship at a time!04-20-2023 09:26
04-20-2023 09:26
That was my understanding too.
But after a few days of the scale being properly set-up it is still on the old Firmware
(it is also synced properly through wifi and bluetooth).
Best Answer04-20-2023 10:23
04-20-2023 10:23
@SuperConker This is what I remember from the firmware versions:
I don't think I would worry too much if it is working and syncing properly.
Laurie | Maryland
04-24-2023 18:08
04-24-2023 18:08
Waiting for the scale to go to sleep before you can re-weight yourself is quite annoying.
Is there really no way to receive the latest Firmware?
The scale is still fully supported by the App still so i don't understand why it can't have the latest Firmware.
Best Answer05-01-2023 06:46 - edited 05-01-2023 06:51
@SuperConker You can try contacting Support and see if they have an answer. It is discontinued, but not on Fitbit's Legacy Device List. I don't know why you didn't get the firmware updates.
FWIW, the longest part of the sync is the time it takes to sync to your router. Sometimes it's fast, sometimes not.
Laurie | Maryland
05-11-2023 05:58
05-11-2023 05:58
Best Answer05-13-2023 05:33
05-13-2023 05:33
It's good to know that you got your firmware updates. Just to clarify, the latest update went to all users worldwide. It fixed an issue specific to Japan.
Laurie | Maryland
