10-03-2022 05:52 - edited 10-03-2022 05:55
Hi, I would so appreciate help. I'm going beyond mad. I've had my scale for ages. Connected working beautifully. Moved (same block), same fibre company, but now I cannot get it to connect to my wifi. Thought it might be router related, but have tried to get it to connect to my wifi at my workplace, also tried my portable router. Goes really well.. shows it's found the wifi network etc... and then "wifi err".
Help.. can't believe how much time I've spent on it. Thank you.
Is it possible to reset the scale to default or something??
10-05-2022 11:24
10-05-2022 11:24
Hello @CharViv
Since you moved you need to reconnect the Aria scale to your wireless network if you make changes to your network name, network provider, network password, or router.
🤞😉 I’m hoping this helps. Please let me know how it goes
Best Answer10-11-2022 14:50
10-11-2022 14:50
I recently purchased the scales and it didn’t refer to connecting with Wi-Fi. It just said to weigh yourself and enter that for your weight in the Fitbit app and save it. Like, that’s the only way? I do that each time. Is that new? I get along with technology OK so I’m confused. I thought it was strange that I had to enter my weight on my own. Help?
