10-14-2022 21:22
10-14-2022 21:22
My Aria has worked for years, with my router which had 2.4G and 5G. Several home items hooked to each frequency just fine. This month, I got a new Spectrum router, it too has both 2.4G and 5G capability, and all my home items hooked easily to each frequency, except the Aria. I do the setup process just fine, and it sees all the wifi in the neighborhood except for mine. Mine doesn't even show up in the list. I heard rumor that newer modems have difficulty with Aria, and I hope that's not true, but evidence is appearing to show otherwise. I do not wish to purchase a different scale, because this one was expensive and very useful and easy up to now. Does anyone have any constructive advice?
Best Answer10-17-2022 08:38
10-17-2022 08:38
Networking Requirements
The Fitbit Aria connects directly to your home’s wireless network and supports the
following network configurations:
Wireless 802.11b standard
WEP / WPA / WPA2 personal security
Automatic (DHCP) IP setup (static IP configuration not supported)
The 802.11b is the most critical.
