04-27-2017
16:37
07:11
JuanJoFitbit
04-27-2017
16:37
07:11
JuanJoFitbit
Hello everyone!
I know this is a hot topic and I have been through all of the support articles, and related threads, but I'm just not finding a solution. I had my Aria since 2015 and here and there I remember running into connection issues. I recently moved and I brought my scale with me but I never connected it to my new WiFi until recently. I tried different set up method: the set up for mac program, set up through the internet browser, set up through a mobile device, and for each set-up, I cannot get past step 4: where it connects to the WiFi. It just says ERR and the scale goes back to SETUP ACTIVE. I have comcast WiFi 2.4Ghz network. Password and WiFi name are all alphanumerical. The scale is in close range to the router. Has anyone else had a similar issue? I had the same internet type at my old home with comcast, so I'm not sure why it won't connect this time.
Moderator edit: format
02-03-2019 15:35
02-03-2019 15:35
I have the same problem, moving an existing Aria scale to a different wifi network. The same thing happened last time I changed wifi networks and I wound up throwing away the old Aria scale and buying a new one. I'm going through the steps in the suggested post but honestly, it seriously should not be that complicated. Aria scale connects new a new wifi out of box fine, but try to change networks and it barfs all over the place.
02-04-2019 06:14
02-04-2019 06:14
@gmcc180 Welcome to our Fitbit Community! Welcome to our Fitbit Community! I'm sorry about the setup difficulties you've experienced with your Aria scale. Since you mentioned that you have a new network, please let me know what is the make and model of your router. Also, let me know if your Aria scale shows any error message.
See you later! ![]()
Best Answer02-04-2019 06:19
02-04-2019 06:19
Thanks for your reply; however, I have given up on trying to connect this scale. Not going to waste any more time on it. Thanks
Best Answer02-04-2019 10:58
02-04-2019 10:58
The error is the same routine others post, ending in WIFI ERR, over and over. I have a NEW Xfinity router, and other articles mention problems connecting to the new XFinity routers. The new router is managed by Xfinity and only gives me access to very few configuration options, no ability to change between g/n and b/g/n myself, and I just don't want to deal with going through Comcast support to get them to change the router config. Finally came up with this workaround.
1 - I had an old Netgear wifi router, and fortunately still new the admin username and password. Connected that directly to my PC with regular ethernet cable. Logged into the router and configured internet port to use the Xfinity (10.0.0.x) network range. Configured the 2.4 wireless network to use a different (192.168.0.x) range with only WPA2-PSK [AES] security, password with letters only.
2 - disconnected the Netgear router from the PC and plugged it into the new XFinity router using crossover cable from ethernet port on Xfinity router to internet port on the old Netgear router. Netgear connected to internet and is now providing wireless network on 192.168.0.x range, with internet access via the hardwired connection on the Xfinity network range.
3 - back at my PC connected to the Netgear wifi network and ran fitbit.com/setup, with the Aria scale just inches away from the Netgear router. Aria finally connected to the Netgear wifi network.
This is more convoluted than many users will want to deal with, but if you have an old wifi router lying around and not afraid to get into the router configuration, it's a workaround.
02-05-2019 06:42
02-05-2019 06:42
@gmcc180 I'm sorry about the experience you've had with your Aria scale. I understand how you feel about this. If you change your mind, I'll be happy to assist you accordingly.
@gmcc180 Thank you so much for sharing the workaround that helped you to get your Aria scale connected to your network. Thank you for sharing since I'm sure that this will help other users.
Don't hesitate to get back if you need further assistance! ![]()
Best Answer02-26-2019 18:59
02-26-2019 18:59
My Fitbit Aria hasn’t synced since the firmware update in December. I haven’t synced since 12/24/2018. I tried all the steps and I can’t get the wi-fi linked backed up. Wish I could get back to factory reset. Took scale near router and still will not sync with WiFi The router has not changed since setting up.
Best Answer02-27-2019 03:50
02-27-2019 03:50
@Ree01 Thank you for joining us in this thread and our Fitbit Community! Let me help you with the connection issues that you are experiencing with your Aria scale. By the way, thank you for troubleshooting this issue before contacting our forums. Please let me know the following details:
- Are you getting any error message?
- What is the make and model of your router?
- What troubleshooting steps have you tried?
Looking forward to your response! ![]()
Best Answer03-03-2019 17:22
03-03-2019 17:22
Best Answer03-04-2019 06:15
03-04-2019 06:15
@Ree01 Thank you for getting back and providing the details requested previously. Since the issue persists, let me go ahead and send your case to our Support team so they can investigate further and provide a solution.
You will receive an email from them soon.
Let me know if you have any doubts! ![]()
Best Answer05-03-2019 19:06
05-03-2019 19:06
WOW Fitbit support is truly a joke. Who works in support? a bunch of 3rd graders? They are completely CLUELESS on how to fix their own product
05-04-2019 05:14
05-04-2019 05:14
I had the same issue. I think it may be related to the security protocol. It worked with WEP and doesn't wok with WPA
So I configured a dedicated wireless SSID with no authentication beside MAC address filtering (the mac address of the scale is in the battery place) and it connected. It will be the only device on this SSID.
I was not able to connect it by WPA/WPA2
Annoying but I will not purchase another connected scale just for this issue.
06-05-2019 09:01
06-05-2019 09:01
I had the same issue when I changed my wifi 2 years ago, and have not been connected since. I just changed my wifi again to a Velop Mesh system and thought I would try it again. Had the same problem initially. When I opened the battery cover, I noticed the MAC address of the scale. I went to my wifi system and went to add device and Chose WPS, then MAC filtering, and I entered the MAC address of the scale. Then went through the setup process as normal and it worked. Maybe I just got lucky.
06-05-2019 10:01
06-05-2019 10:01
Best Answer08-13-2019 15:16
08-13-2019 15:16
My Aria will occasionally not connect, and then will connect on different days, and then not, etc.
The issue may be due to FitBit's use of CloudFlare to block denial of service attacks.
My home is protected by a whole-house VPN. Essentially I pipe all Internet traffic through to a server somewhere in the US so that my ISP can't sniff, nor block services. Today my Aria did not connect again so I tried to get to FitBit's support page - only to receive a CloudFlare error message.
I turned off the whole-house VPN and everything connected fine. Turn it back on (and get a different outgoing IP address from the VPN server) and the Aria still connects.
My router reboots everyday to keep everything fresh. Each reboot causes a new VPN tunnel to be created. Each new VPN tunnel will get a randomly assign IP address depending on which server the VPN provider dynamically allocates to my connection.
My hypothesis is that FitBit's CloudFlare set up rejects connections from some IP addresses and not others. The Aria is connected to the Internet, but when it attempts to talk to FitBit's server the connection request is intercepted and terminated by the CloudFlare service. The Aria then sees this as a connection error and reports it as such.
The Aria is on the home's Wi-Fi network. Its not distance, network changing, etc. Instead it is the IP address that the Aria presents to FitBit (CloudFlare) that is blocked. Some ISPs can change the IP address assigned to a house on a daily basis, others on a monthly basis - reseting the modem will often force a new IP address that may or may not be acceptable to FitBit (CloudFlare).
Best Answer08-31-2019 21:17
08-31-2019 21:17
I too am unable to connect my Aria to my wifi since installing a new modem. I can get through the setup to joining wifi then err.
The modem is a Fritz!Box 7430 YX.
Do you know if there are any issues with this particular modem?
Thanks.
Best Answer02-22-2020 06:41
02-22-2020 06:41
I had this problem. I couldn't get it to connect. Last option I tried was to delete it out of my profile and setup up scale like a intial setup. It went through the complete setup with my new internet no problem. Hope this helps.
02-22-2020 13:54 - last edited on 03-02-2020 17:04 by LiliyaFitbit
Thanks for that, appreciate the suggestion.
Best Answer02-23-2020 06:15
02-23-2020 06:15
So disappointing. Why Is it so difficult to connect an older version Aria to wifi and why can’t I talk to anyone. Best help answer seems complicated. I’m ready to throw in the towel.
Best Answer02-23-2020 11:01
02-23-2020 11:01
I’m trying to delete mine also and start from scratch. Can’t find how to do that either ....,
02-23-2020 18:25
02-23-2020 18:25
Me too am having thesame problem can anyone help please
