08-27-2015
08:32
14:53
08-27-2015
08:32
14:53
01-12-2021 06:52
01-12-2021 06:52
I am having the same problem. I am unable to delete the Aria scale from my account through either the dashboard or app.
My Aria scale stopped syncing after 4 years of use. I have not switched wifi providers or my internet settings in over a year. I have tried the troubleshooting processes for 3 days now to re-sync my Aria.
I am now trying to remove the scale then add it back to see if that helps with syncing, but I CAN'T REMOVE THE SCALE!!!
10-08-2021 07:17
10-08-2021 07:17
Thank you for the instructions on how to remove the Aria... I have been trying for a very longtime to remove it.
01-08-2022 06:22
01-08-2022 06:22
do you know whether it is possibke to use other scale or i have to sell the fitbit watcg and buy something else??? fitbit aria scale is a little **ahem** and this app is **ahem**y too. I can't add weight manually!!!! it does not calculate BMI. buying fitbit watch and aria scale was the biggest mistake ever 🙉🙉🙊🙊🙊🙊🙊🙈🙈🙈🙈🙈🙈
09-11-2022 14:38 - edited 09-11-2022 15:29
09-11-2022 15:34
09-11-2022 15:34
Best scale I found is a Greater Goods WIFI scale on Amazon and using the APP to connect and auto download to FITBIT dashboard. Been using it for years. And it does have issues and measures within .1 of a pound.
01-11-2023 08:58
01-11-2023 08:58
thanks.... not intuitive. jan 2023
