03-07-2019
12:55
11:07
JuanJoFitbit
03-07-2019
12:55
11:07
JuanJoFitbit
I have had my Aria scale for several years, and it has always measured 2-3 pounds heavier than the doctor's office scale with clothes on. How can I calibrate it?
03-09-2019 03:54
03-09-2019 03:54
@higgz1 Welcome to our Fitbit Community! I'm sorry to hear that your Aria is not providing accurate readings.
Please re-calibrate your scale by taking out the batteries for 15 seconds and put them back in. Once you've done this, weigh yourself 5 times in a row and see if the issue gets fixed. Also, make sure that your scale is placed on a hard surface and you are stepping on it barefoot.
Keep me posted on the outcome! ![]()
11-28-2019 09:41
11-28-2019 09:41
Hello. I have tried this and every time I get a different weight off by pounds. Any other suggestions?
03-04-2020 10:35
03-04-2020 10:35
I've tried this. I used a 20 pound weight to test my scale, and it said 21 pounds. Did the above suggestion, now says 20.8
04-07-2020 08:21
04-07-2020 08:21
I tried your suggestion and it didn’t work. I weighed myself 5 times had my son come in and he’s 10 lbs heavier. After he weighed himself, the scale added 2 extra pounds to my weight after that. Pulled out my old scale and there is a 4 pound difference. How do I get an accurate reading? There has to be another way to calibrate.
04-08-2020 07:46
04-08-2020 07:46
This is also the case for me. Multiple weighings right after each other gives different results
04-08-2020 08:34
04-08-2020 08:34
08-03-2020 10:03
08-03-2020 10:03
i feel like if the answer is “keep taking the batteries out and putting them back in,” the actual answer is “no, you can’t recalibrate it”
mine gave me a 5 pound jump a few weeks ago and has been consistently 3-4 lbs higher than my old scale, which matches my doctor’s. i don’t really need that kind of help
12-24-2021 01:21
12-24-2021 01:21
My husband did this by removing a single battery, waiting 15 seconds, and it’s now weighing correctly. (Weirdly, this didn’t work for me when I removed all the batteries). It was previously out by a whopping 8 kgs, but apparently it calibrates according the 4 points / feet on the particular floor it’s on. So previously the scale was on a wooden floor and went out of sync when we moved it to a tiled area.
12-25-2021 15:42
12-25-2021 15:42
Welcome to the Community forums, @Nicole_tc.
Thank you for taking the time to share the steps that worked out for you. It's good to know that your scale is now weighing correctly, I'm sure this will be helpful for other users as well.
Have a great day.
Best Answer08-26-2022 20:21
08-26-2022 20:21
I am frustrated because I have tried this. Also I have Aria not Aria 2 and it changed on me last night and won't go back. It is depressing as I have lost 15 pounds and now the scale is saying within seconds I gained 5 of that back.
09-21-2022 05:47
09-21-2022 05:47
I did this 2x, and the readings were still way off
