10-25-2021
06:46
08:12
BraulioFitbit
10-25-2021
06:46
08:12
BraulioFitbit
How do I change back to pounds from stone weight?
10-25-2021 08:11
10-25-2021 08:11
Welcome, @Penguinicity! It's great to see you around.
Regarding your inquiry about the measurement units, it'll depend on which scale model (Aria Air or Aria 2) you have. If you have the Aria Air, you can tap the button on the back of the scale to switch between pounds, stones, or kilograms. If you have the Aria 2, you can do it from the Fitbit app by tapping on your profile's icon > Aria 2 > Weight Units.
Hope this helps!
