12-02-2017
17:57
14:53
12-02-2017
17:57
14:53
How do I delete Aria? The method described here doesn't give me the option. Aria quit and Fitbit is not standing behind the product.
12-03-2017 02:27
12-03-2017 02:27
Hi @Arya-GoT
On the Fitbit.com Settings Page, open the settings page for your Scale. Click the tab 'people', afterwards click the trash icon next to your username to remove yourself from the Scale.
This removes the Aria from your Account.
12-03-2017 02:27
12-03-2017 02:27
Hi @Arya-GoT
12-03-2017 04:27
12-03-2017 04:27
This worked like a charm! Thank-you!
12-04-2017 07:18
12-04-2017 07:18
Hey @Arya-GoT and @SunsetRunner!
@Arya-GoT, Glad to know that @SunsetRunner's post did help you out. You should select it as a solution. You can do so by clicking on the 'Accept as Solution' button below the post. This helps out other users who have the same questions.
If you have any questions or need any assistance, please let me know.
12-04-2017 09:19
12-04-2017 09:19
Fab ![]()
Happy Fitbitting
12-28-2017 08:07
12-28-2017 08:07
Great help many thanks!!
07-01-2018 05:49
07-01-2018 05:49
I just bought a new Aria 2 to replace my previous Aria. Is there a way to delete the original Aria scale, but completely but keep the history of weight measurements?
I contemplated not buying another Aria because it did not last long, but could not find another scale that would sync with a wearable and give me the reading I wanted. Looked at Qardio scale but didn't see a wearable to go with it.
It has taken me over an hour to get everything setup and synced! Way to much time and things did not go as the directions said they would.
Best Answer07-07-2018 12:14
07-07-2018 12:14
@Arya-GoT Thanks for joining us in our Fitbit Community! Thank you also for choosing the Aria 2 over other brands. Regarding your question, please follow the steps that shared my friend @SunsetRunner in his post above in order to remove your old Aria from your account.
Rest assured that unfortunately, when you delete the Aria from your account, your history data won't be saved since that device syncs apart from the Aria 2.
Don't hesitate to get back if you need further assistance! ![]()
Best Answer01-12-2019 16:33
01-12-2019 16:33
I have been trying for over a year to delete the Aria scale that I purchased, setup, then returned due to it not working well with our network. I have read thru the comments on this forum and viewed the screen shots. Unfortunately I do NOT have the trashcan or delete option. I don't even see the People/add people info - maybe I had to delete it while the device was still connected? Am I stuck with the Aria being on my app dashboard and my web dashboard for life? Very frustrating for sure. The problems I had with the Aria scale just keep living on with me. I definitely wouldn't advise anyone to buy it, which is disappointing because I really love the other Fitbit products and have been a Fitbit user for 10 years.
01-13-2019 01:33
01-13-2019 01:33
09-16-2020 15:05
09-16-2020 15:05
I also did not see the People option on the Dashboard. And although nothing on my Dashboard showed me the Aria, it was still on my iPhone app. Finally, I deleted the app from the phone -- disregarding the "this will delete all your data" message (I was fed up by this time) -- and re-installed it from the App Store. Logged in to the app. Success. The Aria was finally gone, and my data was all there. Maybe this will work for someone else.
Best Answer11-13-2020 12:17
11-13-2020 12:17
Is there really no better way to get the old Aria off the Fitbit app than to delete and reinstall the app?!? This seems shockingly incompetent on the part of Fitbit. There is a "remove" option on the app that shows up for the newer scales, but not for the old Aria. Was this just a complete miss on their part?
Best Answer11-15-2020 08:53
11-15-2020 08:53
I decided to go to People as described in earlier posts and delete myself and the dam scales.
Best Answer03-04-2021 12:48
03-04-2021 12:48
Click on the icon for your head. Select Aria Scale go to “People Using” delete your name and anyone else and it will go away.
01-12-2023 00:55
01-12-2023 00:55
Singularly one of the worst pieces of tech I have had to deal with. Fitbit appear to be Apples lesser qualified younger brother. Very poor that this exists. It doesnt give you confidence that if you buy a piece of tech that it will continue to function moving forward.Goodbye Fitbit, hello (more expensive, but works !) Apple
