01-09-2019 10:40 - last edited on 09-04-2019 08:45 by MatthewFitbit
I have just started using the aria 2 and I'm having difficulty reading the lean vs fat graph. Can anyone explain to me in simple terms what it's showing me? Many thanks in advance.
01-10-2019 07:48
01-10-2019 07:48
@Bradders474 Welcome to our Fitbit Community!
Regarding your question, the dark blue line is weight -- coming from the scale or manually entered. The white line is the calculated lean mass. The area in blue is the calculated fat mass. The area below the white line is the calculated lean mass.
Please don't hesitate to get back if more questions arise!
01-22-2019 08:38
01-22-2019 08:38
Hello that is clear to me now, but why there are no numbers ( labels) displayed on the graph ?
it would be easier to read a labeled graph with body fat% and muscle %.
Can it be done?
01-25-2019 08:03
01-25-2019 08:03
@joannenader The different versions of the app sometimes display differently. On the iOS app version of the Lean vs Fat graph, there are two arrow pointing apart. Tap on the arrows and rotate to landscape. A light touch and hold over any entry shows a box with the date, lean mass, fat mass, and total weight.
I hope this is what you are looking for.
Laurie | Maryland, USA
01-25-2019 10:16
01-25-2019 10:16
Thanks! This is what I was looking for 😊
01-29-2019 08:03
01-29-2019 08:03
@joannenader I'm so glad to hear that the information that shared @LZeeW helped you. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often!
04-16-2021 08:51
04-16-2021 08:51
Hi sometimes for the same weight the lean or fat % will go up or down. How does it determine the lean abs fat breakdown? And it only works when using the Aria 2 scale (which I have)?
07-18-2021 05:19
07-18-2021 05:19
This is so helpful! Thanks.
