How to reassign weights for people with close weights
My wife and I have fitbit accounts and linked the fitbit aria 2 to each acct.  We assigned different icons to us on the aria 2.  This worked for awhile.  Then my wife stopped using it because it would associate my icon when she weighed.  It does not do the ask thing where you tap the check mark or not to validate the icon.  How can we force this to happen so we can start getting her weigh ins assigned to her.  Really like the way the aria 2 weights flow straight in to myfitnesspal.  Working great for me, but not wife.
7 REPLIES 7
@katanabeach, in either the Ftibit app, or the Fitbit.com Dashboard, open the Aria 2 and select Recent Weigh-Ins. Change the weight readings to the correct user for each weigh-in. This will cause the scales to learn the person associated with those weights.
So my husband and I both use the scale and have fitbits and all is well. However, my daughter doesn't have fitbit but uses the scale and we weight very close to the same as well as fat % so then it syncs her weight to my account. How do I have her make the scale see her as just a guest to weight in?
@Mikeandi3, have her create a Fitbit account - she does not need a Fitbit tracker for that - and then use the Fitbit.com dashboard to send her an invitation to use the scales. She then would also use the Fitbit.com dashboard to accept the invitation. The scales then could track her weight, BF%, etc., just as you and your husband do.
@katanabeach It's great to see you in the Fitbit Community and welcome aboard @Mikeandi3! I would like to follow up and would like to know if you managed to get your weigh ins assigned accordingly after following the great tips that shared my friend @USAF-Larry.
Looking forward to your responses! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
Tks for reply. We are already doing that. The problem was it was assigning
her weighins to my account/icon. Even though she has an icon assigned to
the scale. We weighed repeatedly and it started prompting to choose icon.
Now it prompts less often and is assigning correctly when it doesn't.
I will give that a try later today. Thank you
@katanabeach Thank you for providing the details. As an aside note, I'd like to share this help article, which explains how to reassign weights in case you need this for future references.
@Mikeandi3 Thank you for taking the time to try the workaround shared above. Please don't hesitate to get back if you need further assistance.
See you guys later! Smiley Happy
