02-10-2017
04:22
14:53
02-10-2017
04:22
14:53
It seems the last post on this was from 2014, and the app is now completely different - so none of the previous answers are true anymore!
Can somebody talk me through how to remove Aria from my fitbit? I need to do this so I can try setting it up again to get it working on my wifi...
12-06-2017 06:07
12-06-2017 06:07
@TrixieTexas It's good to have you aboard in our Fitbit Community! I'm sorry to hear that you decided to stop using your Aria scale. Regarding your question, please log in to your web-based Dashboard. After this, click on the "gear" icon which is located at the top right corner of the page. After this, select the Aria, select the tab "People and you'll see a list of the users that used the scale. Please click on the trash can icon that is next of each users' initials and the Aria should be removed for every user.
Let me know if more assistance is needed my friend!
02-11-2017 03:16
02-11-2017 03:16
@ClacTom It's great to have you aboard in the Fitbit Community! In order to remove your Aria scale from your account, you need to go to your Dashboard (Via web-Dashboard only). Click on the "gear" icon, select the Aria scale. Select the "People" tab and you'll see the list of the people that are using the scale. Next to each user, there is a "trash can" icon and click on it for every user in order to remove the scale and you can set it up again.
Let me know if more questions arise my friend!
02-26-2017 06:18
02-26-2017 06:18
Thank you it worked for me!
02-27-2017 04:18
02-27-2017 04:18
@Vanessastrick82 Thanks for joining us in our Fitbit Community! I'm so glad to hear that the tips above helped you. Thanks for keeping the update here.
I'd like to invite you to visit our Discussions board, where you can share your experiences, meet people and create new topics.
Hope to see you in the Community more often my friend!
05-06-2017 11:30
05-06-2017 11:30
Done everything everyone said to do and sitt don't connect to my wifi it worked until we had to change our router now it won't connect ...... This is really upsetting
05-08-2017 08:07
05-08-2017 08:07
@Wehooe Thanks for participating in our Fitbit Community! Since you mentioned that you have changed your router, please make sure that it has the settings that the Aria needs to connect with it. Please find the settings needed in this help article. Once the settings have been corrected, please try the setup process one more time.
Keep me posted on the outcome my friend!
07-08-2017 10:32
07-08-2017 10:32
It still show up in my app...not my web dashboard.
07-10-2017 06:20
07-10-2017 06:20
@Christophersen It's great to see you in our Fitbit Community! Seems odd that your web-based Dashboard is not showing your Aria scale. Please try logging out of your account, after this log back in. By doing this, your Dashboard will re-fresh and should show your Fitbit devices.
Let me know how it goes my friend!
07-23-2017 05:43
07-23-2017 05:43
Same here, I've tried everything mentioned as well. This shouldn't be this difficult. I loved the concept of the Aria but since I've changed routers it's been of no use to me. Such a waste, would not recommend to others for this reason alone.
07-24-2017 06:57
07-24-2017 06:57
@MochaMartha It's good to see new faces in the Community! I understand that you feel frustrated due to the setup process with the new router. Please visit this help article and make sure that your router has the correct settings that are needed for the Aria scale. Once this has been done, try the setup process as described in this post.
I'll be around if more assistance is needed my friend!
07-24-2017 15:50
07-24-2017 15:50
07-25-2017 05:35
07-25-2017 05:35
@MochaMartha Thanks for getting back! I really understand your frustration regarding the protocol that the Aria needs to connect. I also appreciate your feedback and comments. I'll forward this info to our team since this helps us to keep improving our services and products.
Don't hesitate to get back if you need further assistance my friend!
11-27-2017
13:41
04:23
JuanJoFitbit
11-27-2017
13:41
04:23
JuanJoFitbit
I went on my dashboard and do not see a way to deete the weight icon. My scale is still showing even when I logged out and went back in. When I remove it, it only “hides” the icon. I need to remove the scale to re-install.
I may not need to delete if I can just get it to connect to my new phone.
11-29-2017 04:21
11-29-2017 04:21
@Lisaduley Welcome to this thread and our Fitbit Community! I would like to follow up and help you with your inquiry. Regarding your question, if you want to connect your Aria with your new phone, there is no need to remove it from your account. You just need to log in as usual after installing the app on your new phone.
Let me know if you have additional questions my friend!
11-29-2017 12:19
11-29-2017 12:19
11-30-2017 04:26
11-30-2017 04:26
@Lisaduley Since you are getting a "WiFi ERR" message, please follow the troubleshooting steps that recommends my friend @SunsetRunner.in this post. Those steps are for this type of issues specifically.
12-03-2017 09:50
12-03-2017 09:50
I've gotten rid of my Aria entirely and would like to have it stop showing up in my device list. I can't figure out how to remove it entirely.
12-06-2017 06:07
12-06-2017 06:07
12-06-2017 06:20 - edited 12-06-2017 06:23
That worked, thank you!
12-11-2017 08:30
12-11-2017 08:30
@TrixieTexas I'm so glad to hear that the instructions that I mentioned above helped you to get this issue resolved. Thanks for posting the update here.
Have you heard about our Discussions board? If you haven't, in this board you'll be able to create new topics, tell your experiences and meet more fitbitters.
Have a great week my friend!
