04-16-2020
11:19
07:11
JuanJoFitbit
04-16-2020
11:19
07:11
JuanJoFitbit
I've updated the software, installed - reinstalled - rebooted - re re re re re re..... numerous times and the ARIA will not sync. What's wrong with the scales. It's an expensive product it should work longer than this!
Moderator edit: updated label
04-21-2020 11:30
04-21-2020 11:30
Which scale do you have? And what do you mean you have updated the software? The scales are self updating.
04-21-2020 11:48
04-21-2020 11:48
if it's an older scale & you have a newer wifi router/networking equipment see:
https://community.fitbit.com/t5/Aria-Scales/Can-t-connect-to-my-new-wifi/m-p/4196163/highlight/true#...
