02-11-2022 04:38
02-11-2022 04:38
I have accidentally deleted my starting weight that synced from my aria scale to my Fitbit. I really want to track my journey from the start. Does anyone know if I can get it back on my Fitbit please? I can’t see any type of delete folder? Thank you.
02-11-2022 05:12
02-11-2022 05:12
Hello @Harry109 and welcome to the Community. As a rule, you can't undo a deletion in the Fitbit app, but you should be able to re-enter it by logging it manually. I can do this on the iOS app. Tap on the "+" sign on your weight tile. Tap on the date and choose the correct date. Tap on the weight and enter the number you remember. You can also tap on the % body fat and enter it, too.
Laurie | Maryland
02-12-2022 08:32
02-12-2022 08:32
02-13-2022 05:21
02-13-2022 05:21
@Harry109 Not in the Aria 2 section. You use the Weight tile on mobile app. If you tap in the middle of the tile, tap on the "+" sign in the upper right or the bright pink Log Weight. If you tap on the "+" sign on the weight tile, you will go directly to the Log Weight page. Remember, you must change the date or it will log as today's weight.
Laurie | Maryland
