09-06-2020 21:22
09-06-2020 21:22
I want to store my Aria 2 under my dresser - I would usually just slide my scale out, weigh myself, and slide it back. Will this cause the scale to recalibrate every time? If so, its going back. Thanks 🙂
Best Answer09-07-2020 06:06
09-07-2020 06:06
Hi @Lauraglo, welcome to our Fitbit Community! Regarding your question about the way you will store your Aria 2, I'd like you to check out this help article, under the subject "How should I store and clean Aria 2?", which explains the better way to store your scale so it doesn't re-calibrate frequently.
Let me know if more questions arise.
