Is Aria still accurate?
So I just bought aria (2nd hand) and its already discontinued but is it still good? Is the accuracy good? I don't have extra weighing scale so can't tell if it's accurate.
2 REPLIES 2
Great question.
I believe it is accurate within a couple pounds. The body fat percentage is usually within 5% which I probably as good as you can get for that older tech.
The issue I tend to run into is that I have to weight myself twice, the first time is appears to add a couple pounds. The second time it is much more accurate.
I just got one of these today I would say definitely not accurate at all. It is consistently 20 pounds over with no way of adjusting it. FitBit Mods will tell you it's okay because it's consistent with itself. How it is they can sell a product that is used to weigh anything and not give it a calibration setting is beyond me.
