10-18-2020
00:39
11:11
JuanJoFitbit
10-18-2020
00:39
11:11
JuanJoFitbit
Hi, I have both scales. I know version 2 is not safe to use whilst pregnant but is version 1? Thanks.
Moderator edit: format
Best Answer@Sarah_in_london Neither the Aria nor the Aria 2 is safe to use while pregnant. They both use the same technology to estimate body fat.
Laurie | Maryland
Best AnswerBoth scales send a very small current through the body.
Is this really unsafe for the fetus?
Best Answer@Rich_Laue Fitbit has a warning, the exclamation point in a triangle, saying do not use if pregnant. Apparently, a Withings scale can be put in a pregnancy mode that turns off the body fat measurement.
Until a manufacturer is ready to put a statement on the device that it is safe, then I recommend against it.
Laurie | Maryland
