10-30-2019 08:02
10-30-2019 08:02
Hi,
on my Aria scale, I swear it used to have a Lean mode option. I no longer see that.
am I crazy or can someone validate. Seems like it might have just changed with a new firmware or something.
10-31-2019 08:36
10-31-2019 08:36
I have this issue too. Possibly iOS update? My BF% jumped 7% overnight.
Best Answer11-05-2019 08:58
11-05-2019 08:58
I don’t think it has anything to do with iOS. I even went to desktop and logged into settings and the option is gone.
i hope they just didn’t kill it, in efforts to drive upgrades. Would be a crazy thing to remove a base feature like that.
i am 41, 6’1, 185lbs, I run 15+ miles a week and occasional half marathons, can bench 225, do 18 pull-ups, and I’m like 20% body fat according to the scale.
11-08-2019 15:52
11-08-2019 15:52
Yeah, I do caliper readings and sit around 13.7 % and the scale says 19% or 20%.
05-11-2020 06:31
05-11-2020 06:31
Ugh! I have been trying for the last hour to get it back into Lean mode but now it's gone. Glad I'm not the only one. Won't waste any more time trying to figure this out. Disappointing they removed this!
11-11-2020 08:49
11-11-2020 08:49
I think it went a few months ago. I suspect it’s a ploy to get us to upgrade to Aria 2
11-11-2020 10:23
11-11-2020 10:23
You can change it, but last time I checked, you CANNOT change it using the app. You have to log into your Fitbit profile in a web browser and do it that way. Which is stupid. I struggled to find it too.
11-11-2020 10:38
11-11-2020 10:38
11-30-2020 09:28
11-30-2020 09:28
Hi there - Can you help me to find the lean setting?
I'm looking in the Aria device settings, but all I see are the scale name, and units (pounds).
Thanks!
06:28
17:26
12-01-2020
06:28
17:26
Hello @PaulYoung This may or may not work. I have an Aria 2, but I searched some images and I see a similar page for the Aria. When you are on your Aria settings pageon your web dashboard, you have a choice of measurements and people. Choose people and tap/click on your image. Is the choice for lean mode there? That's where it is for the Aria 2.
I would love to know if this is an epic wild guess or no help at all.
Laurie | Maryland
12-01-2020 07:24
12-01-2020 07:24
12-01-2020 07:38
12-01-2020 07:38
I found it. I had to click on my name and the selection appeared.
BTW - my issue seemed to be the opposite of everyone else's, 2 years ago I had set it to LEAN, but post-covid onset I don't qualify anymore.
It was stuck on LEAN, and did not reset with the recent updates.
Thanks to you both for your help!
01-31-2021 09:20
01-31-2021 09:20
Sooooo, now I am having issues with the scale, where I have set lean in my profile, but it definitely is not taking. Says I’m in lean, but the numbers are definitely that of not lean (60% higher than it has always read).
anyone else seeing this?
