05-23-2022 17:15
05-23-2022 17:15
I recently moved house, and my Aria 2 scale is now totally disconnected from the (new) wifi, and won't sync with my phone. Resetting it does not work. Is there a suggested troubleshooting procedure for this?
(Everything I found said that I should have added the new wifi to it while I was still on the old wifi, which...doesn't make a lot of sense, frankly?)
05-24-2022 10:18 - edited 05-24-2022 10:23
Hello @EmilyVB
This link I’ll help you set up your Aria 2 scale since your wireless network changed when you moved: https://blog.rottenwifi.com/fitbit-aria-change-wifi/
😃Hopefully that helps getting things sorted out. Keep me posted
Hello @EmilyVB
