10-22-2023 16:46
10-22-2023 16:46
It has worked in the past but for the last few weeks it hasn’t. We’ve tried resetting it. Deleting it and setting it up from scratch. But nothing works. Any help would be appreciated.
10-24-2023 16:35
10-24-2023 16:35
Start over. Meaning take the battery out and perform the setup. And as soon as you put the lid back on th e batteries, push two corners so it goes into setup mode.
2. Make sure you are connecting to 2 ghz not 5. Netgear is known for not handling 2.4ghz cleanly going back and forth between 5ghz.
3. If you have a Nest router, that is even worse. Just make sure you are using 2.4ghz. If you can get into your router as admin, assign a static IP to your Aria
