02-05-2014
23:05
14:53
02-05-2014
23:05
14:53
I have tried everything to find my wireless network on the scale. I ran the program through the browser, checked my router settings, even tried the phone app, nothing will even detect my wireless to commence the rest of the setup. The scales work as a guest but i want to be able to connect to my fitbit account as i have the flex as well. This is seriously annoying me and i'm getting to the point of pack up and return the lot! I restarted everything, disconnected it all, and alas the wireless works on my smart tv and my android phone however this device refuses to find it?
10-28-2019 19:29
10-28-2019 19:29
Hello. No matter what I do. Refreshing wont show my network and joining a different network says that my network doesnt exist.
I'm getting very frustrated cause I bought the scale and have not been able to use it. It's become a paperweight and I'm so close to trashing it.
10-30-2019 02:42
10-30-2019 02:42
have tried ‘join other network’ ? aka manual method - where you type in the SSID network name and it’s login password
10-30-2019 06:01
10-30-2019 06:01
12-27-2019 10:48
12-27-2019 10:48
I don't know if this will help, but...
I recently upgraded my home wireless from a Linksys access point to a fancy UniFi setup with multiple access points, and had a terrible time getting the Aria to talk to my wireless network.
Turns out there are a couple of headaches involved with the 1st gen Aria scales.
I'd been struggling with my Aria for a while, and it wasn't until I saw this discussion on the Ubiquiti forums that the light came on for me. Basically, the Aria can only "see" networks that support really low data rates, and my UniFi network was set...to not support really low data rates. So the trick was to enable minimum data rate control, then set the minimum data rate to 1mbps. Crazy. It may be a setting available to you in your router/access point as well, I know I've seen it in routers I've owned in the past. Hope this helps someone.
02-07-2020 03:38
02-07-2020 03:38
I have tried those steps and confirm my router's wireless settings, but no networks are visible on the setup and I simply get the message "Can't find the device". It was formerly connected but I changed my router recently, but not the SSID or the password, and now there is no recognition of any networks.
Any suggestions would be appreciated.
Best,
B.H.
02-07-2020 09:28
02-07-2020 09:28
What kind of router do you have? Have you confirmed that the 2.4GHz mode is active?
02-08-2020 15:53 - last edited on 03-02-2020 17:00 by LiliyaFitbit
This is now sorted ...I ended up buying a new Aria
02-28-2020 09:32
02-28-2020 09:32
This is the problem. New routers don't even offer the 802.11b option, so would need to find an older wifi extender that does connect to 802.11g, but can rebroadcast in 802.11b. Then Aria should be able to find the network and set up (security? who needs it!)
03-03-2020 04:40
03-03-2020 04:40
Shut up with your “great to have you onboard” nonsense and get your crap equipment working. Why do you sell such junk?!!
04-01-2020 20:50 - edited 04-01-2020 20:51
@wrbluepearl wrote:I don't know if this will help, but...
- ONLY works with 2.4GHz wireless networks
- Requires that 802.11b legacy support be turned on in your wireless router/access point
- Requires that the 1mbps data rate be enabled for your 2.4GHz wireless network.
I'd just like to thank you for your input.
I also have a Unifi access point that my Aria was connected to and working with fine until last week.
It just stopped seeing it and when I went to set it up again it could see all other wifi networks available just not my one.
I created a second SSID on my access point as test and it found that and could connect fine.
Both networks were exactly the same except for name and password but when I did what you said and enable the minimum rate stuff it started working again.
Dunno why this happened in the first place. Maybe a firmware update on my UAP-AC-PRO but it's all good now so thank you!
04-02-2020 10:43
04-02-2020 10:43
Yeah, it did actually work fine for about the first six months that I had the UniFi setup, then just stopped working one day. My Cloud Key was set up to auto install updates, so it was probably some default setting value that changed when the update was rolled out. It took me about four hours of searching, rebooting the scale, and general fooling around to get it working again. I don't know that this is really Fitbit's fault, as the first-gen Aria is now relatively old (2013-ish), and the stuff that Ubiquiti did was not something you see in consumer-grade wireless gear.
04-26-2020 22:53
04-26-2020 22:53
try using incognito mode in the web browser (after your router setting is 8011b). That worked for me.
04-27-2020 12:49 - edited 04-27-2020 13:01
could you guide my to where i set the 2,4GHz in Unifi controller
Solved😁👍
04-27-2020 13:42 - last edited on 07-15-2020 20:22 by LiliyaFitbit
so sorry but I just couldn't do it at all and ended up buying a new Aria and that set up easy by just following the instructions....it was a while ago now so I cant remember exactly what i did sorry
07-14-2020 07:02
07-14-2020 07:02
I have had connection issues finding and connecting to WiFi since day 1! Countless hours trying to find YouTube video to help but I am still not connected! In the “available wireless networks” page my network is not showing... I type in the name in the join other network section and still unsuccessful. Then I look at my scale and it is flashing “network detected”... well where is mine? I’m standing right by the router with the scale. Why have this scale of it doesn’t work???? If your technology can’t find my network of course I can’t connect! Dated and sad I spent money on this!
08-18-2020 05:35
08-18-2020 05:35
So this may be too little too late, but I just spent the last 5 hours fighting with this issue and I managed to figure it out.
To be clear the exact situation I had was when the scale would scan for WiFi networks it would show some networks, but not mine. I thought it was some kind of caching issue where it would not show networks it had connected to before.
Ultimately it turned out that even though I had 802.11b enabled on my router, I needed to turn on some kind of "legacy mode" that allowed for very low bandwidth connections. When I turned that one, my network showed up in the list of available networks.
I don't think this is technically any kind of issue with the scale, other than it's using super old wifi standards and a lot of modern routers either don't support them anymore or don't support them by default.
Hope that helps.
08-18-2020 13:19 - last edited on 08-26-2020 20:07 by LiliyaFitbit
Thanks for this feedback , but this isn't my problem. My issue is that out of the blue My Aria simply stopped updating data to my Fitbit app. The only thing I could put it down to is that my ionic went completely flat and I had to recharge it. In my app my Aria is synced with my app but when I update and sync on my phone my Aria isn't updating data to the App. Someone in this group suggested that I take a battery out and replace it a few times but now it's just returning a V27 error message. Argh!!! I think I will now have to try removing and re-syncing the Aria in my Fitbit App...Such a pain!! Honestly Fitbit...your customer experience record is not good and you really leave yourself wide open for a competitor stealing all your clients
08-18-2020 22:49
08-18-2020 22:49
08-19-2020 14:02 - last edited on 08-26-2020 20:08 by LiliyaFitbit
I ended up buying a brand new Aria because my internet provider would not help me and the new Aria linked ok and was working fine until now ...even though it's all linked up to my app and was syncing and updating perfectly, out of the blue now it isn't updating to my app when I sync my app...Argh!! To be honest I'm so over it!!!
Blanche
11-12-2020 21:50
11-12-2020 21:50
Watched the video.. Exactly how I'm trying to setup.. I can see all random wireless connections from neighbors, but it doesn't pick up my network? Please help.
