08-29-2019
15:49
14:53
08-29-2019
15:49
14:53
I moved apartments and tried to sync to wifi. Got the wifi err message (tried several times) and now the Aria is stuck on set up active mode. I've tried taking the batteries out, I've tried getting it to measure my weight (it does but then reverts back to set up active). I've searched this forum and not found anything that works. Help? Is my Aria now a brick? I have to say that for such an expensive gadget, this SUCKS.
08-30-2019 12:06
08-30-2019 12:06
I have not been able to set up my Aria for the past year and a half!! It will weigh me, but will not sync with my Fitbit Blaze. Search "Aria" and you will see that no one is able to connect! I have tried multiple times over this past year and a half with absolutely no success. Fitbit says it is Comcast, Comcast says it is not them...no resolution. Very frustrating, since it was working fine until 2018, and that seems to be when they all went to hell!!
Good luck, but I wouldn't expect much more than what you have now.
08-31-2019 16:55
08-31-2019 16:55
same here nothing works!
09-01-2019 17:49
09-01-2019 17:49
I can not even get to set-up. Watched video and saw person clicking on right corner of dashboard page for set-up. I clicked everything in that corner and no set-up. When I pull battery out it just gives the web address to go to set-up. Scale does not go to ready to activate. By the way I have an Ionic that syncs well to my Pixel 2XL and I have Cox internet with 300 Mbps speed. Probably will return if I can't get it to work.
09-03-2019 14:43
09-03-2019 14:43
I am having the same problem. I have had the Aria for a couple of years and it’s worked fine. Suddenly, it won’t sync and says it can’t find my device. I see that Fitbit is introducing a new scale. I am thinking the old aria scales are going the way of the Blaze. It’s planned obsolescence. If the problem isn’t resolved, I am finished with Fitbit forever.
I have tried all the troubleshooting things and it still will not work. I guess it will go to the electronic graveyard along with my Blaze.
