01-07-2021
11:09
10:51
01-07-2021
11:09
10:51
Hi everyone.
We are aware that Aria users are encountering an issue when trying to sync. Our Team is investigating the situation and we hope to bring you all back on track very soon.
Thank you for your understanding and patience. We will post more information here when we have an update.
01-06-2021 13:48
01-06-2021 13:48
Me too, I have tried everything this morning. Batteries in and out, WiFi off an on, forgetting the device and trying to connect it again. NO SYNC. it’s SO annoying.
01-06-2021 13:54
01-06-2021 13:54
I've woken up to the same problem as well. Almost like something has stopped the older version of the scales from syncing in general and they want us to upgrade. Very frustrating.
01-06-2021 14:02
01-06-2021 14:02
Exact same thing with me
01-06-2021 14:04
01-06-2021 14:04
I have exactly the same problem. Read in a different post that it may be that the problem is originated by logging through the Facebook account, hence problem may be resolved by changing the login credentials. I’ll try that to see if works
01-06-2021
14:05
06:04
JuanJoFitbit
01-06-2021
14:05
06:04
JuanJoFitbit
I wonder if a representative from FitBit is going to bother confirming what’s happening.
I’ve never logged in through FB.. let me know if that fixes it though
Sent from my iPhone
Moderator edit: merged reply
01-06-2021 14:07
01-06-2021 14:07
I don't use facebook for my login info, it's a standard email/password set up.
Seems rather coincidental that suddenly everyone is having this problem.
What scale version does everyone have?
01-06-2021 14:08
01-06-2021 14:08
Hi @lengrady you've posted on the community forums, where you get peer to peer help on some issues. I'm sure people are working at Fitbit today, but they don't always post on the forums. You'll see a Fitbit Moderator reply to various posts, but they aren't customer support.
01-06-2021 14:19
01-06-2021 14:19
01-06-2021 14:27
01-06-2021 14:27
I think I have first generation. I bought mine in like 2016 or something. Surely they can’t just stop it working so we all buy new ones?! Would have thought they’d at least give us some warning! But yes, hugely coincidental.
01-06-2021 14:48
01-06-2021 14:48
01-06-2021 14:51
01-06-2021 14:51
I am having the same issue!😠
01-06-2021 14:59
01-06-2021 14:59
Im haviung exactly the same issue. I've changed the account password, the wifi signal to b, taken any special characters out of the SSID and password. Just get linking then no sync...
01-06-2021 15:57
01-06-2021 15:57
Same here. Maybe there has been an update??
01-06-2021 16:42
01-06-2021 16:42
These scales have always been on the brink of "breaking". . .I haven't found a good replacement that does wifi syncing to my fitbit account. I don't want to use a bluetooth scale. I don't weigh myself with my phone in my hand.
01-06-2021
16:48
06:06
JuanJoFitbit
01-06-2021
16:48
06:06
JuanJoFitbit
I have the same problem - seems to be a global issue and Fitbit will have to sort this out. Has anyone seen any updates?
Is this only a certain type of Aria? I have had mine for years so wondering if this is like Apple and it's a way to force an upgrade?
01-06-2021 17:04
01-06-2021 17:04
01-06-2021 17:13
01-06-2021 17:13
01-06-2021 17:20
01-06-2021 17:20
I've also tried more than a dozen times to reset the scale. It has worked well for the past several months and then started not working this morning. It appears that Fitbit has an issue and it would be great if they resolved it soon.
01-06-2021 17:42
01-06-2021 17:42
Hi @Odyssey13 , thank you for you reply and help.
Hello @lengrady , a warm welcome to the Community! Thank you for sharing your experience with the Aria.
The servers are ok, still, I notified or team to check it again.
Do you receive any notification (icon) on the display of your scale?
If so could you describe it?
I'll be expecting your reply!
01-06-2021 18:13
01-06-2021 18:13
I have the same problem with an original Aria. It won't connect today with a SYNC ERROR. I keep trying to set it back up again and it gets stuck either at "WIFI ERR" or "LINKING TO". I have also rebooted my router just in case.
I'm glad it is not just me. I think something has gone wrong with the original Arias.
