01-07-2021
11:09
10:51
01-07-2021
11:09
10:51
Hi everyone.
We are aware that Aria users are encountering an issue when trying to sync. Our Team is investigating the situation and we hope to bring you all back on track very soon.
Thank you for your understanding and patience. We will post more information here when we have an update.
01-07-2021 14:26
01-07-2021 14:26
I am having the same problem
01-07-2021 14:30
01-07-2021 14:30
I sent in the logs that were generated when I tried to use the old setup app.
They indicate that it is a server issue on your end.
(personal info redacted, emphasis added)
-----------------------------SUMMARY:-----------------------------
Date/time stamp: 2021-01-06 20:12:47
Error Code: Server didn't confirm Scale pairing.
Error Type: Issue related to fitbit.com communication.
OS Version: Microsoft Windows 10 Professional (build 19042), 64-bit
Client Version: 1.0.4.175
Aria SSID: Aria Axxxxx
Network SSID: xxxxxxxxxx
Encryption type: WPA2PSK (AES)
Wireless Mode: 802.11n
Active Networks:
Wi-Fi
Inactive Networks:
Ethernet
Local Area Connection* 1
Local Area Connection* 2
01-07-2021 14:47
01-07-2021 14:47
Great work lissakay! Good detective work. It's almost too much of a coincidence that so many of us experienced issues all at the same time.
01-07-2021 14:48
01-07-2021 14:48
Hello everybody! Good news! I 've been informed that the situation got solved. You should be able to sync your Aria again.
Thank you for patience and your feedback.
Let me know how it goes.
01-07-2021 14:57
01-07-2021 14:57
Well I'll be dipped. It works now.
Server back online?
P.S. FYI - 20+ years of IT/database/server troubleshooting and break/fix experience. Always go for the logs first.
P.S. 2 Y'all hiring?
01-07-2021 15:12
01-07-2021 15:12
I can confirm it is working and syncing again for me.
Good work everyone for making a bit of noise to get the attention this needed.
And it would be nice next time if Fitbit can send out the comms as soon as you find out there is an issue at your end. It would have saved everyone here a lot of time and anguish.
Touch wood there is no next time!
01-07-2021 15:19
01-07-2021 15:19
I'm going to take a wild, but educated guess -
Someone left an open tran on the database and it locked up the server.
01-07-2021 15:23
01-07-2021 15:23
Thank you all good now - 2 hours of trying to reset and came close to ordering new 🙁. Thanks to the forum for pushing this issue 👍
01-07-2021 15:24 - edited 01-07-2021 15:26
@lissakay wrote:I'm going to take a wild, but educated guess -
I blame Cloudflare and complacency, along with cheap labour...
01-07-2021 15:33
01-07-2021 15:33
Mine is now also syncing... pleased it is sorted but very disappointed with Fitbit’s response to me earlier suggesting I buy replacement scales.
01-07-2021 15:49
01-07-2021 15:49
i have tried twice now to step thru the fitbit.com/scale/setup/start and i keep getting SYNC ERR. No Joy. Please let me know wha else to try!
01-07-2021 15:59
01-07-2021 15:59
My Aria is still not syncing same issues as yesterday will not connect to the network. I am in Hong Kong.
Another day more time spent with fitbit malfunctioning products and on message boards and to a incompetent, undertrained and incapacitated service team.
The cynic in me says they intended to no longer support this product however stupidly actioned it during January in lockdown when everyone is focused on diet and health. So there was a backlash.
After this no longer planning to get anymore products after 6 years. Going to get Withing scales and look at watches and port all my stats to Apple health. I am still waiting on fixes for Ionic outages in the last few months. A lot more options are now available since fitbit came on the market and I don’t see it lasting longterm with the current strategy of sell poor quality and give bad support.
01-07-2021 16:01
01-07-2021 16:01
Okay, twice with my laptop failed to sync. I then tried using my iPhone and success. I don’t understand why the laptop didn’t work, as it is wifi only but at least it is functional.
01-07-2021 16:08
01-07-2021 16:08
Looks like it's working for me now too. Thank you!
01-07-2021 16:16
01-07-2021 16:16
Mine is also now working - used my phone. Laptop and Ipad would not connect for some reason.
01-07-2021 16:20
01-07-2021 16:20
01-07-2021
16:28
16:48
JuanFitbit
01-07-2021
16:28
16:48
JuanFitbit
Really? I have been having trouble synching my Aria for all the years I have owned it!
Nothing but trouble anytime I have to change the network. Moving? Have fun. Expect to have months of frustration, cursing and wanting to throw your Aria out the window!
Seriously, you people need to fix this problem. It's a joke. I will be looking at another company soon if you don't fix this problem, and my pricey Versa 3 will follow my Aria out the window.
Susan
Moderator edit: removed personal information
01-07-2021
16:38
07:06
JuanJoFitbit
01-07-2021
16:38
07:06
JuanJoFitbit
Ok thanks I will try now!
I sent all my data to Apple Health it is good but doesn’t collect theOxygen saturation. Good luck with new watch, I am pondering too!
Sent from my iPhone
Moderator edit: merged reply
01-07-2021 16:42
01-07-2021 16:42
This was my issue today too, from the post above it looks like they may be experiencing technical issues. I tried everything and nothing worked until I replaced the batteries in my scale and it is now working fine! In the process of trying different things I did remove my device from my account removed the batters, push the pin hole at the back and replaced the batteries! I also emptied my cache from my phone prior to setup and rebooted my modem.
I hope this helps others!
01-07-2021 16:49
01-07-2021 16:49
crazy, I weighed yesterday and it worked. Then my husband go on to weigh about 10 minutes after me, it wouldn't sync.
