10-29-2019
09:39
06:09
JuanJoFitbit
10-29-2019
09:39
06:09
JuanJoFitbit
How often should I have to calibrate it because I have to lean it on its side to for storage?
I’d rather not have to recalibrate it but I don’t have the space in my bathroom for it to sit flat. And even if I did I’d have to worry about the cats laying on it and activating it draining the batteries.
Moderator edit: updated label
10-29-2019 16:43
10-29-2019 16:43
Not quite page 9. Was page 6 for me but for anyone searching here's what I seen.
Ensuring accuracy
Use these tips to get the most accurate and consistent readings from your scale:
● Use your Aria 2 while barefoot. The scale cannot measure body fat percentage
if you’re wearing shoes or socks.
● Make sure your feet are dry before weighing yourself.
● Place your Aria 2 on a hard, flat surface during use. Using the scale on a soft
surface - like carpet or linoleum - may affect the accuracy of the Aria 2's
readings.
● Balance your weight evenly between both feet while standing on the scale.
● Weigh yourself at the same time each day to see consistent trends. Your
weight and body fat percentage will naturally vary over the course of the day.
● If your Aria 2 is picked up and moved between measurements, or stored
sideways against a wall when not in use, the scale will go through a calibration
process the next time it is used for weighing. Up to two consecutive weigh-ins
will then be required before your scale is recalibrated and again displays
consistently accurate measurements.
NOTE: Body fat percentage, BMI, and lean mass measurements require that your Aria
2 scale has been set up with your Fitbit account. You do not need to
complete this setup to weigh yourself.
10-29-2019 15:35 - edited 11-01-2019 06:39
Hi @Techy
Please refer to Page 9 of the pdf (Page 6 of the Aria Manual)
https://staticcs.fitbit.com/content/assets/help/manuals/manual_aria_2_en_US.pdf
I hope this helps!
10-29-2019 16:43
10-29-2019 16:43
Ensuring accuracy
readings.
