04-05-2018
23:29
14:53
04-05-2018
23:29
14:53
Is there a way to reset the Aria to Factory settings so it forgets the current WiFi network?
I have done everything to try and get my Aria to sync with my Fitbit app but when trying to connect to the Aria WiFi - my device connects but then when clicking 'I'm connected' the connection fails.
I would like to remove my WiFi from the Aria to see if that will let me set it up like a new scale again.
Thanks
Linda
09-11-2020 11:51
09-11-2020 11:51
Just called support. Their response? My device is out of warranty, so they will do nothing. After I followed the steps recommended ON THE FITBIT SUPPORT SITE, my device is now non-functional, and Fitbit is assuming no - zero - responsibility for providing really bad guidance. I am a very unhappy camper at the moment!
09-11-2020 13:31
09-11-2020 13:31
10-17-2020 00:37
10-17-2020 00:37
Was there a resolve for this issue
10-26-2020 20:02
10-26-2020 20:02
I have had a similar experience. My Aria would not allow me to change the wifi and would not synch. I took a battery out. No help. tried to push the hole in the back to reset and everything went dark. Changed the batteries, cleaned the contacts, No luck. Any other suggestions?
10-26-2020 22:43
10-26-2020 22:43
10-27-2020 18:18
10-27-2020 18:18
Fitbit replaced it. Even though it was out of warranty I suspect it was still covered by Australian Consumer Law so we got lucky. New Aria is a lot better.
10-28-2020 06:37
10-28-2020 06:37
10-30-2020
03:54
05:11
JuanJoFitbit
10-30-2020
03:54
05:11
JuanJoFitbit
My Aria was eating up my battery every 15 days 6 months ago. Support was not helpful as out of warranty.
Like Apple who was asked to replace battery free of charge by court, they should be asked to replace even if out of warranty.
These tech hardware companies want you to buy their newer products every two years by updating the software so your scale, watch, iPhone and iPad go slow or do not sync or work. If they cannot sell new, they will go out of business!
Anyway, I tried to fix battery problem by resetting to factory reset but it kept coming up with WiFi error for number of times although it was connecting tomAria WiFi.
I left the Aria without battery for more than 10 minutes and pressed reset few times.
I than tried set up and hey presto it connected.
I hope this helps you and others.
PS.
Today after rebooting the WiFi router, Aria had lost connection and same problem of ERR.
However,after number of tries as stated above, managed to connect again.
Good luck.
See my solution just posted
How old was your Aria exactly?
Moderator edit: merged reply
10-30-2020 04:17
10-30-2020 04:17
Not sure, but I think we bought it in 2014 or 2015.
01-20-2021 08:34 - edited 01-20-2021 08:59
I could carbon copy your experience with customer service even the asking for a discount, and I thought it was because I’m a Scotsman 😀
4 pages of the same problem all over the world shows that it is not fit for purpose and although it has a two year guarantee it is one of the most expensive scales
i bought a set of Salter scales yesterday with Bluetooth and more functions for £20 or $25 and it has a 15yr warranty, it talks to my iPhones and Android phones though google app and worked as it should
Fitbit should be embarrassed at all these common complaints and lack of help from customer services, not the agents fault as they tried to be so helpful and polite
09-11-2021 03:21
09-11-2021 03:21
Also, having inserted a pin to reset the scales - it bricked them. Scales are dead in the water and no longer do anything.
REALLY BAD ADVICE GUYS!
01-20-2022 08:13
01-20-2022 08:13
I have changed the name and password of my aria and I’ve made a new account on Fitbit to try get it connected again it just won’t connect no matter what I do. Reset it took batteries out same message comes up Wi-Fi ERR I am fed up of having to keep setting it up now be aswell getting rid of it.
06-01-2022 21:27
06-01-2022 21:27
My aria doesn’t have a hole to reset it tried all night to reset but can’t do it it is the first scale out there
12-26-2022 05:14
12-26-2022 05:14
Moderator - please bring attention to another problem people seem to have issues with which is the ERR message. There is a thread started for days and no attention from Fitbit - frustrated and I am not the only one
12-28-2022 08:45
12-28-2022 08:45
@UNDER20CARBS wrote:Moderator - please bring attention to another problem people seem to have issues with which is the ERR message. There is a thread started for days and no attention from Fitbit - frustrated and I am not the only one
Please note this is a user community. If you need help directly from Fitbit you need to contact support.
12-28-2022 10:17
12-28-2022 10:17
