Sllly question -- ❌ or ✅ on the Aria 2?
ANSWERED
When I step on my Aria 2, it sometimes is unsure if I'm me -- it shows my icon with an :cross_mark: and :white_heavy_check_mark: on each side. How am I supposed to respond to this? Is there a way to respond on the scale itself, or should I go to the app?
Moderator edit: format
1 BEST ANSWER
Accepted Solutions
Not silly - took me a while to figure out.
With your toes, tap the quadrant of the scale next to correct symbol, check mark if you, X if not.
1 REPLY 1
