Smart Scale recommendation?
My Aria scale stopped recording to Fitbit, likely because it is no longer supported. I'm looking for a new scale that accurately measures body fat, since the Aria I have only measures with your feet (not the most accurate). Does anyone have a recommendation for one with a telescopic handle that is compatible with Fitbit?
4 REPLIES 4
I had no idea what you were talking about, but then found several on Amazon searching for "8 electrode body fat scales".  A few say the connect to f1tbit (sic); assume they mean Fitbit.
Aside: a reason many Aria 1 scales stopped working is because they couldn't handle upgrades that many routers have undergone since then to handle faster internet/wireless speeds or some such that it would take a techie to better explain.
It turns out the problem is with the new preview. When I switch back to the old Fitbit version, my weight from the Aria scale appears. When I switch back to the preview, it is there. Definitely an issue with the preview. I've sent this in via Feedback.
@JRzMom   I saw a list of compatible devices for the Personal Health Coach and am angry with myself that I didn’t bookmark it.  The list I saw only had the Aria Air as a compatible scale.  I don’t think I would upgrade my scale right now.  I would switch back and forth between the two versions while this feature is under development.
Laurie | Maryland
I love my Runstar scale. I literally use it everyday. It does weight, body fat, visceral fat, protein, water level, all stuff.
It gives body fat, lean mask, and weight weight data all to Fitbit. It literally shares the data instantly.
https://a.co/d/aTJ4qrI
