09-01-2022 18:11
09-01-2022 18:11
Everyone, log into fitbit on the safari page and follow the wifi instructions. I did it and my original Aria connected to no problem.
Make sure when you turn your scale on, it will try to connect to the old internet and it says "tap to change" make sure you do that, then you can log into the Aria internet on your phone wifi and then on safari you can select your wifi and it will connect.
09-11-2022 05:12
09-11-2022 05:12
I don’t get a message to change internet. It will just give message that there is no connection
