09-11-2022 05:06
09-11-2022 05:06
My fitbit aria scale worked fine for 5 years connected to my wifi, but suddenly connection error.
i tried to connect again, it sees the network (messages: saving, connecting to wifi) but than gives WIFI ERR and goes back to SETUP ACTIVE.
i moved the scale close to the router, retried several times from different ipads. No succes.
really no clue how to get it to work again. As far as I know nothing changed in my setup.
09-11-2022 07:43 - edited 09-11-2022 07:45
Anything change with your wifi? New router? Sometimes original Aria won't connect to newer wifi protocols.
 Best Answer09-11-2022 08:29
09-11-2022 08:29
No, nothing changed as far as I know. Same router, same provider, no changes. Also, no problems for 5 years. Always worked fine.
In the setup mode the scale seems to try to connect. Saving data (I guess password for wifi) and says “connecting” but than comes back with WIFI ERR and goes back to setup active mode.
i started this reconnecting business when I noticed that my data was not synchronized and I saw on the scale a sign for wifi with a x indicating no wifi.
09-18-2022 02:30
09-18-2022 02:30
Mine is doing the exact same thing. It just worked Sept. 1st for me.
09-22-2022 03:52
09-22-2022 03:52
I'm having the same problem. No wifi connectivity.
09-24-2022 14:01
09-24-2022 14:01
I am having the same exact problem. Can someone at Fitbit assist?
09-25-2022 04:24
09-25-2022 04:24
My Aria Ii is doing the same last two days. Reboot wifi both days. Information on new weigh-in is in the app but it won't pick up Aria weigh-in.
 Best Answer09-26-2022 16:32
09-26-2022 16:32
Changed the batteries and can weigh in and it syncs to my phone but keeps saying setup active
 Best Answer09-26-2022 16:54
09-26-2022 16:54
