01-23-2014
21:24
14:53
01-23-2014
21:24
14:53
cant load configure the aria, after reading help formums that I too used a extender to originally load settings, to change settings im asked to "tap". Ive been tapping but it turns itself off.
01-23-2014 21:42
01-23-2014 21:42
You need to have the scales on a hard surface and step on then with the weight of a foot. Tapping with a hand will not suffice.
After reseting my Aria and then linking it to the primary wi-fi source, NOT a wi-fi extender, I used my Iphone to link the two and it now works.
05-31-2014 08:57
05-31-2014 08:57
This was definitely THE answer. Tapping on the scale didn't work to get it to enter setup.
Thanks!
Marie
12-23-2016 13:35
12-23-2016 13:35
Nope. All it did was weigh me.
12-28-2016 06:29
12-28-2016 06:29
@wjmiller132 It's great to see you in the Community! I would like to follow up and would like to know if you were able to set up your Aria scale or if still need help with the "tap to change" step of the setup process.
Looking forward to your response my friend!
12-29-2016 02:57
12-29-2016 02:57
Hi!
I have just attemted to change the wifi on my Aria, but when i gave it a tap with my foot, all it did was weigh me. Please help!
Jakey
01-01-2017 08:41
01-01-2017 08:41
I am having a simimlar issue. Any way I tap nothing happens ither than the weighing process continues. Has anyone found what / how to tap? Do I stand on the scale and tap with on e foot, or stopp off the scale and tapp with my foot? Other?
01-04-2017 03:27
01-04-2017 03:27
@JakeyC It's great to see you aboard in the Community and thanks for joining us @TAK61! Please take a look at Matthew's post, which includes great tips that will help you to know how to tap your Aria scale.
Keep me posted on the outcome my friend!
04-25-2017 08:42
04-25-2017 08:42
Whoever was the UX designer they should find them and fire them immediately
04-26-2017 07:12
04-26-2017 07:12
@cicorias Thanks for joining us in this thread! I really appreciate your feedback and comments in regards the UX. I would like to follow up and would like to know more details about the issue you are experiencing with your Aria scale since I'd like to help in order to turn that bad experience into a good experience.
Catch ya later my friend!
05-11-2017 06:38 - edited 05-11-2017 06:41
I hope Everyone on the Aria UX Design Team has the Day they Deserve! #FAIL
ps. I'm not any Stranger's 'Friend.' Those from FitBit who might respond to this are welcome to call me Mr. Westra or Sir.
05-11-2017 06:42
05-11-2017 06:42
I honestly don't know how any reasonable human could question the fact that the UX is horrible. You should really actually try your product and ensure you're being empathetic about your end-users. Not taking it from a perspective of having done it 10 times a day. This is rare scenario, but the UX was done in a way that makes it so complicated and difficult to trigger. It's really a basic scenario, but undoubtedly you've done no real user testing.
06-18-2017 08:00
06-18-2017 08:00
I seriously thinks it's a bot. I read the same exact replies on completely different threads.
12-03-2017 07:49
12-03-2017 07:49
In case you guys did not figure it out yet, you have to step on and off quickly when it says to tap.
Sorry, but that’s not great communication, better wording would have avoided this mess altogether.
01-30-2018 11:54
01-30-2018 11:54
Same here 3+ years later...
01-31-2018 00:42
01-31-2018 00:42
When it says Tap ....... A better way to do it is just hold the aria on your lap.....using both hands press the two hinges at the the bottom with your fingers and placing your thumb on the scale (just like pinching) for 2 seconds only
04-21-2018 08:05
04-21-2018 08:05
Thanks for posting these instructions..
Frankly - I can't understand why Fitbit/Aria would use the word "Tap" when they mean "Press the two lower corners"
Idiots!
04-23-2018 05:18
04-23-2018 05:18
@TexJD58 It's great to see you in the Fitbit Community! I want to follow up and would like to know if your Aria scale could be set up or is your scale unable to sync? If the issue persists, please let me know if you get any error message.
@TALHA Thanks for joining us in this thread and our Fitbit Community! Thank you also for sharing some tips in order to set up the Aria scale. I'm sure this will help other users that experience the same issue.
@NYCmariposa Welcome aboard to the Fitbit Community! I appreciate your feedback and comments about the way the sensors need to be pressed. This info will be forwarded to our team since this helps us to keep improving.
See you all later!
12-09-2018 14:11
12-09-2018 14:11
This is the most ridiculous setup Ive seen. Been trying to change the WiFi for several hours no with no luck. Complete waste of time. I’m done with FitBit
12-10-2018 04:50
12-10-2018 04:50
@DrivingMeCrazy It's great to see you in our Fitbit Community! I'm sorry about the setup difficulties you've experienced with your Aria scale. I want to follow up on this and would like to know a couple of details that will help me to assist you properly: Is your Aria displaying any error message during the setup process? Have you made other changes to your WiFi (router, router settings or WiFi password?) What is the make and model of your router.
In the meantime, make sure that you are following the setup process as is described in this help article.
Keep me posted!
