01-12-2019
19:02
10:06
JuanJoFitbit
01-12-2019
19:02
10:06
JuanJoFitbit
My aria scale got wet and I have been trying to reconnect it to my wifi that it was originally connected to. I can get it as far as joining wifi then on the scale i get wifi err. No explanation for it or what to do next. Very frustrating. I've also notice if my versa is connect it blocks the aria from trying to even install when you select the aria scale it just blinks back to the beginning. has anyone got any idea as to what to do. or if I should just buy a new scale.
Moderator edit: format
01-12-2019 20:43
01-12-2019 20:43
figured out my own screw up. In the process I did realize to reinstall the aria i had to unpair my versa. The versa blocks the installation of the aria scale.
