08-22-2020
12:23
11:25
LizzyFitbit
08-22-2020
12:23
11:25
LizzyFitbit
Hi all! I just purchased the Fitbit Aria Air scale to better track my BMI and lose weight. I went to setup the device through the Fitbit app on my phone and the Fitbit site on my laptop, but when I got to the page stating "Connect to the scale's network," neither of my devices (Galazy S20+ or Microsoft Surface 2) could discover the network starting with "Aria." I tried manually entering in the scale's MAC address and SN to my home WIFI network to make it visible/discover-able, but that did not do the trick. I really don't want this purchase to be a waste but if anyone has any insight to this connection error, I would love to find out why this is happening and what I can do to ensure a sound connection. 🙂 Thanks!
09-08-2020 11:41
09-08-2020 11:41
Hi @kaithumb. Welcome! It's great to see a new face around the forums.
I'm glad that you got the Aria Air and thanks for your efforts while trying to set it up to your account. Let's work on this together. Just to confirm, may I know how many batteries are included in your scale? I'm asking this as the Aria Air will connect via Bluetooth as any other Fitbit device, however the Aria will require to connect to the Aria network before connecting to your WiFi connection.
Assuming you have the Aria Air, I'd recommend to try the following steps:
On the back of your scale, find the battery compartment and pull out the plastic tab. Your scale will turn on.
Look forward to your comments.
09-08-2020 11:41
09-08-2020 11:41
11-04-2020 17:38
11-04-2020 17:38
Hi @LizzyFitbit! Thank you for responding to my inquiry two months ago. My apologies for this delayed response! Your steps helped out and my Aria Air is functioning properly now. My device has 3 batteries if that helps with future inquiries similar to mine. Thank you so much!
11-05-2020 11:39
11-05-2020 11:39
Hi @kaithumb. Welcome back to the forums!
You're very welcome and thanks to you for trying the steps suggested in my post. I'm glad you were able to get the Aria Air connected to Fitbit account and I hope you continue enjoying the experience with your scale. By the way, if you have time, check out the Health & Wellness board where you can make friends and encouragement to reach your fitness goals.
Have a great day! 😊
01-16-2021 13:32
01-16-2021 13:32
Odd,
I have an iPhone and have the same issue.
Your instructions don’t make sense, for the iPhone, Fitbit app.
There is no, profile picture>setup device, in the Fit app, for me to setup blue tooth.
Aria Air, does not show up under iPhone settings/Bluetooth as a device.
All my other devices show up, including the Fitbit Charge 4.
01-17-2021 07:25
01-17-2021 07:25
I am having a similar problem with my Aria 2 and iPhone. The phone can not find the scale when searching for Bluetooth devices. My scale is right next to my phone.
01-17-2021 09:29
01-17-2021 09:29
Found the answer
fitbit uses it’s own device handling software.
It appears on the main page when you press the icon on the extreme upper left of the screen. Aria describes the icon as a face. (It looks more like headphones than a face).
When you press it, the account page shows up. “Add Device” is in the middle of the screen”
After you press Add Device it’s pretty straight forward.
01-17-2021
09:34
12:33
LizzyFitbit
01-17-2021
09:34
12:33
LizzyFitbit
Aria 2, Is wifi.
Aria Air is Bluetooth.
Aria Air has its own device software and doesn’t show up as a device on
your cell phone’s blue tooth devices.
Moderator Edit: Personal info removed
01-18-2021
13:02
18:58
01-18-2021
13:02
18:58
Hi @C0ppert0p and @WorldWideWillie, welcome on board. It's good to see new faces around the forums.
@C0ppert0p, I'm glad that you were able to connect your Aria Air and thanks for sharing your insights.
@WorldWideWillie, thank you also for your efforts while troubleshooting your Aria 2. Let me explain that the Aria 2 needs to be set up in the Fitbit app and not in the Bluetooth settings. That being said, please check if the Fitbit app is updated and make sure your WiFi meets the requirements described here. Then, open the Fitbit app, tap the profile icon at the upper left corner, scroll down and tap Set Up a Device. Choose your Aria 2 from the list and follow the onscreen instructions. You can also watch this video for detailed instructions.
Keep me posted.
