Which whole home routers will connect to Aria 2?
Currently I have ATT fiber with the u-verse modem/router with a mesh network and I have tried everything to no avail to get it to connect. I have probably wasted 4-5 hours on this in the last week and half.
I would be willing to upgrade my system to a faster router/mesh system but I want to know for sure that the device will work before spending 300$ + on these systems.
Will the aria 2 work on the following or some other whole home solution for fiber connection speeds?
From what I can tell they should, but then again so should my current router.
thanks.
Moderator edit: format
1 REPLY 1
@internetguy01 Welcome to our Fitbit Community! I'm sorry for the late response. However, I appreciate the information you provided about your router and the time you've taken to get your Aria 2 connected.
Regarding your inquiry, the Aria scales connect with any router that run the protocol 802.11b and and bandwidth 2.4GHz. These settings can be changed or reviewed with your Internet service provider.
As a side note, please let me know if any error message appears during the setup process. If so, please provide more details and at what point of the setup process the Aria 2 gets stuck.
Looking forward to your response! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
