aria 2 not showing bmi on app
Aria 2 not showing bmi on app.
Moderator edit: format
6 REPLIES 6
@charbel   Please check the following settings in your app.  Tap on Account > Aria 2 > People Using This Scale > Your name > make sure Show BMI is toggled to On.
It's been a while since I set up my scale.  If I remember correctly, the default setting for show BMI was toggled to Off, for some obscure reason.
Please let us know if this does not help.
Laurie | Maryland
Hi and thanks for the reply
Actually it is on but still i cant see it
Sent from my Samsung Galaxy smartphone.
@charbel   Your weight tile on the dashboard will show your weight and your % body fat.  Tap on the weight tile and you will see your weight trend, your weight summary and logged weights.  You can scroll to the left on the weight trend graph.  You will see Lean vs Fat, Body fat %, then BMI.
Does this help?  Sorry I misunderstood your original post.
Laurie | Maryland
Actually it is helpful but so i scroll left on the scale or in the weigh-in in the app
Thanks
Get Outlook for Android
@charbel   Scroll on the app, not the scale.  Your app view might look different from mine.  I am an iOS user, you use Android.
Tap on your weight tile on the app.  Then scroll.  The weight graph should scroll until you see this:
This is the fourth graph after scrolling.This is the fourth graph after scrolling.
Laurie | Maryland
@charbel It's great to see you in our Fitbit Community! I would like to follow up on the issue that you are experiencing with your Aria 2 since it's not displaying your BMI.
I'd just like to know if the issue persists or if you managed to get the issue resolved after following the great troubleshooting steps that shared my friend @LZeeW.
If you found her post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
Looking forward to your response! 😀
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
