04-25-2023 02:45
04-25-2023 02:45
I am looking to upgrade my body weight scale. I want the weight to sync to my Fitbit app instantly without having my phone on me. I'm not up to date with scale tech. Is the Aria scale still worth getting? Or do you recommend a different body scale?
04-25-2023 06:46 - edited 04-29-2023 05:08
Hello @parker521 and welcome to the Community. The Aria Air is the only scale available from Fitbit. It's a simple body weight scale that measures weight, then calculates your BMI in the Fitbit app. It syncs using Bluetooth, but your Fitbit app must be open and your phone needs to be in Bluetooth range to sync. Even with your app open, a weight dialog box appears on your app and you must accept or cancel it. If you want to weigh yourself and walk away, then the Aria Air won't meet your needs. Even if it met your needs, it's my personal opinion that the Aria Air price point is too high for its features. I don't have experience with any other brands, so I can't help you with that.
Laurie | Maryland, USA
