07-07-2023
12:47
14:29
LizzyFitbit
07-07-2023
12:47
14:29
LizzyFitbit
There has been a consistent difficulty with setting up the Aria Air scale since Fitbit moved to Google. When attempting to pair the device, an error occurs.
09-27-2023 05:20
09-27-2023 05:20
09-27-2023 05:38
09-27-2023 05:38
Sadly all customers views are ignored by both Fitbit and Google it seems.
09-27-2023 05:58
09-27-2023 05:58
Since you just received your scale, you would probably be better off returning it while you can and getting a different brand. Or return for a refund and wait till the problem is fixed. I wouldn't hold on to it hoping for a fix, as it's been quite some time with no fix in sight. They might have it fixed today, 2 months from now, or never.
09-28-2023 05:32
09-28-2023 05:32
Hello, this is beyond frustrating that this isn't fixed yet. When will a fix be available so that I can connect to this scale?
09-28-2023 07:52
09-28-2023 07:52
The current state of a fix is one of:
- it's on our backlog to look at, we hope to soon
- we started looking at it
- we can reproduce the problem, but don't know what's going on
- we identified the error, working on a fix
- we are testing a fix
- the fix didn't work, trying something else
- we have released a fix
With no real updates from Fitbit, it seems like it really isn't being looked at yet.
09-28-2023 11:34
09-28-2023 11:34
They'll care if they lose enough Premium subscribers.
They're losing me... I'm only really interested in my weight and steps but still on my free trial period.
09-29-2023 14:11
09-29-2023 14:11
It’s been 2 months since you posted that the team was aware of this aria air syncing problem. Maybe they should just let us go back to logging in with Fitbit instead of google. Things worked then. and that would give the team more time to work on the problem without impacting the users.
09-29-2023 14:20
09-29-2023 14:20
This was fitbit support’s response to my aria air problem;
“We'll be glad to help you connect your Fitbit Aria Air.
09-29-2023 15:09
09-29-2023 15:09
10-01-2023 02:36
10-01-2023 02:36
My scale was on older firmware. I have moved from android to ios. On ios my first step was to move fitbit account to google account so I did. Then I erased my Sense 2 and Aria Air from that account. Then synced Sense 2 properly. But when syncing Aria Air I did it quickly. I think it was in ota mode without properly reseting it from android device. I have paired it with ios in that way but it did went with something went wrong. But it was in my list of synced devices. It did not work. From that time I have removed it from synced devices. Properly cleared Aria Air. Updated firmware. Removed batteries. Every little thing multiple times but it all ended up in something went wrong. So I think scale is not properly cleared from system or something got messed up in scale itself from pairing it in that ota mode. Hope this will help.
I did create second google account and synced it but it did recognize it at last synced date when it showed up in my devices after ending in same something went wrong.
10-01-2023 02:52
10-01-2023 02:52
10-01-2023 10:36
10-01-2023 10:36
So I have had my aria air for 10 months. It worked great for 6 months. Then google had us change our Fitbit login to be google login. Ever since, my “smart” scale turned into a stupid scale- if I want my weight recorded to fitbit app, I have to do it myself. I had a digital scale prior to buying the aria air and it worked great but I had to record the weight myself- now I am sorry I “upgraded” and got rid of the digital scale. That scale at least did what it was advertised to do.
I consider this to be a major defect. My scale is still under warranty. Will fitbit take this scale back and refund my money? Or is this scale just going to be discontinued since fitbit can’t seem to fix this? Why in the world wouldn’t this have been tested prior to changing to google login so it didn’t affect the aria air users?
10-01-2023 10:43
10-01-2023 10:43
10-01-2023 14:01
10-01-2023 14:01
I gave up on my Aria Air completely now and don't even bother trying anything new... they're just a useless waste of money.
I have a set of INSmart scales that have their own app and that app connects to my fitbit app so I can actually have my weight sent to the fitbit app and it records it fine.
It's worth looking, if you have an older set of smart scales if the app for it connects to fitbit. It'll be easier than manuallt recording your weight.
The other issue I have, right now, is why this thread is listed as 'solved' or 'answered..? It clearly isnlt.
10-04-2023 00:42
10-04-2023 00:42
So uh ... do you have any more information to share since (checks notes) seventy days ago??
10-04-2023 01:48
10-04-2023 01:48
They are trying to say why all those integration when you can manually input no more than 5 digits.
I will make it work with or without Aria Air.
What is your opinion about making more trash.
10-04-2023 06:27
10-04-2023 06:27
10-04-2023 12:22
10-04-2023 12:22
I bought the aria air from amazon & bought the ASURION 3 Year Personal Care Protection Plan. Sounds like if google doesn’t fix the syncing issue by the time the manufacturer’s warranty runs out, I can file a claim with them because the device doesn’t work as advertised & I will be able to get my money back.
10-04-2023 14:44
10-04-2023 14:44
10-05-2023 07:07
10-05-2023 07:07
Has there been any updates on resolving this issue?
This is beyond frustrating.
