08-08-2015
18:00
14:53
08-08-2015
18:00
14:53
I have been trying to set up my scales. I go through almost the whole process until its trying to connect to WIFI and then a "WIFI ERR" shows up on the scales. I have checked my settings on my modem and it is on WPA2 PSK. I have also reset the modem more then once and tried the set up various times with no sucess. Does this have something to do with my modem? I have never had so many issues trying to set up one of my devices and I am considering just returning your item as I didnt realise I would have so many issues (obviously I dont want to return it). Can anyone shed any light on this issue?
08-10-2015 10:42
08-10-2015 10:42
Hi there @kandrades86. It's great to see you in the Fitbit Community!
If you're getting this wifi err when setting up your scale, I would recommend which is the Protocol that your router uses. The Aria scale works with the Protocol 802.11b and some other routers run the protocol 802.11n or 802.11g. If you don't know which is the protocol that your router uses, you can get in touch with your service provided an they can check on this for you.
Please let me know how this goes!
08-10-2015 10:42
08-10-2015 10:42
08-10-2015 12:04
08-10-2015 12:04
I am having the same problem. I was able to connect and use my scale for months. I had to reinstall the OS on my macbook and now when I try to reinstall the Aria it will not sync with my network. Same moden as always. Double checked my password twice. Tried using the software and the web versions on both my computer and my phone.
08-11-2015 05:50
08-11-2015 05:50
Same problem - set up tried it every which way - I see a moderator saying - go back to service provider - REally? Do you know how long that takes to get some help?
So far 2 hours of my life I'll never get back - anyone with a bin! As usual no one to actually speak to for help...Arrrggghhh Returns
policy anyone know what I can do about that?
08-11-2015
06:11
05:58
08-11-2015
06:11
05:58
Hey there @warre. Welcome to the Community!
If you don't know which is the protocol that your router is using, the only one who will know for sure is your service provider. You can still get in touch with the Support Team for further assistance and when it comes to the return policy, you have a 45 day return window. For more details, you can review it here.
Anything else, please let me know!
08-11-2015 08:19
08-11-2015 08:19
08-13-2015 18:42
08-13-2015 18:42
I have just spent the last TWO hours on the phone with my internet provider. They told me that ALL modems are set to 802.11b by default. I had my modem reset and reconfigured and yet I STILL get the wifi ERR message.
Ive been so excited about getting my aria scales, that now I am on the verge of putting them back in the box and sending them back for a FULL refund. I have one more network to try and if this network DOESNOT work, then bye bye aria.
so disappointed like many others.
09-09-2015 15:30
09-09-2015 15:30
I think this is a known issue with the Aria, and if you say the right things to customer service, they will replace it at now cost. Here's my story:
I had this problem on my Aria, and after calling FitBit customer support, and telling them that I:
1. Had gone through the laptop (Mac) setup app multiple times
2. The Aria had worked fine previously, the only thing that had changed was my wifi password
3. I am 100% positive I was using the correct Wifi SSID and password in the setup up
They emailed me immediately, asking for my Fitbit account credentials, and shipping address. They shipped me a replacement Aria within 10 days.
09-12-2015 18:44
09-12-2015 18:44
Sucess with connecting my Aria! Hopefully this will help someone. It took me more than four hours (and 30+ years of experience on computers) to get past the "WIFI ERR" part of the setup. Good luck!
I tried both the mobile and desktop app, but never got past the final stage, as the "WIFI ERR" error message would flash on the scale. Here are the steps I took:
1. I have a D-Link Wireless Router (DIR-815) and made the following changes:
a) Ensured that I was using the 2.4ghz band.
b) Ensured that my wireless mode was set to: 802.11mixed (n/g/b)
c) Changed the name of my wifi network to only letters
(not sure if this made a difference)
d) Changed my security from WPA/WPA2 (enhanced) to disable security
(no password needed; this last step made all the difference.)
2. Once I made those changes, I was able to connect to the Aria (with both the desktop or mobile app -I tested both.)
3. I then went back and changed my router securtiy from no-security to WEP and followed the steps outlined in the below link, and ensuring that my password had no special characters (i.e. !?_)
4. I might have been able to connect by originally changing the routher setting security to WPA/WPA2 to WEP directly, but I didn't bother to test that theory (four hours is long enough!)
5. I understand that Fitbit needs to get their products "out the door" as soon as possible due to increasing competition, but I know few friends that would be able to have circumvented this error. I also now have (slightly) decreased router security in order for the Aria to connect.
I do love my Fitbit HR, and have lost more than 10 pounds. Thanks, Fitbit!
10-11-2015 20:47
10-11-2015 20:47
Okay, my Aria was working and now it's not! I keep on getting the ERR msg. I have taken my batteries out a zillion times. Once I was able to successfully connect to Aria but when I stepped on it I recieved the ERR msg again.
Checked the protocols and they are all the recommended protocols fitbit recommends.
Now that I have exhausted all the advise--what is next?
10-12-2015
06:32
05:58
10-12-2015
06:32
05:58
Welcome to the Community @EO_Walnut!
If you've already tried to remove all the batteries and put them back in after a while and you have checked all other suggestions and you still get the ERR message, I'd say that the best thing to do is to get in touch with the Support Team and they will be happy to get you back on track!
Any other thing, I'm here to help! 🙂
11-25-2015 15:32
11-25-2015 15:32
Solution provided is not the correct solution. All routers typically come with the mix of all of the protocols (e.g. b/g/n and even some as high as n/ac). In this case, the problem is, and you should update your dcouments with this, is IF you use any numbers or under scores, it won't work. I named mine "home_network". I had to change it to "homenetwork" and then it worked. If you add any spaces or under score characters, it doesn't seem to like it. Thanks
11-26-2015 03:23
11-26-2015 03:23
I would strongly advise not leaving your router security set to WEP, it is very easy to hack. My Aria is running fine connected to my router running WPA2. Looks like the SSID naming convention was your original issue.
Best Answer12-27-2015 18:05
12-27-2015 18:05
Hi.
We've been having this problem too.
Our router is set to 802.11b/g/n, yet we haven't been able to get past the wifi err message.
We went back to the shop and they replaced the unit, but we are still getting the error message.
We emailed support on the 17th December 2015 with details of what we've been doing and attached the scale log file and haven't heard back
Can you help?
Thanks
12-27-2015 22:42
12-27-2015 22:42
12-31-2015 11:00
12-31-2015 11:00
I changed the name of my router and dropped the underscore and it worked.
Best Answer01-01-2016 07:19
01-01-2016 07:19
I have the correct protocol. I was on the phone with support for over an hour and we still could not figure it out. This is so frustrating and I love my Aria. Why can't I get it to recognize my new wifi? I need this remedied quickly! I have a Mac and Iphone. Please help!!!!!
Best Answer01-01-2016 08:48
01-01-2016 08:48
Router transmitting 802.11b ?
SSID name without any fancy characters or spaces ?
Best Answer01-01-2016 20:48
01-01-2016 20:48
Hi all, I had this issue earlier today setting it up for the first time as well. The way mine finally worked was when I dumbed down my WiFi login credentials. That is, I only used A-Z and 1-9 in my router's username and password. If you have @#$%^!_- or anything like that in your username or password, try removing it and trying again.
01-11-2016 09:22
01-11-2016 09:22
If you have any symbols in your router name (SSID) or your password, it won't connect.
