08-08-2015 18:00 - last edited on 09-10-2019 14:53 by MatthewFitbit
I have been trying to set up my scales. I go through almost the whole process until its trying to connect to WIFI and then a "WIFI ERR" shows up on the scales. I have checked my settings on my modem and it is on WPA2 PSK. I have also reset the modem more then once and tried the set up various times with no sucess. Does this have something to do with my modem? I have never had so many issues trying to set up one of my devices and I am considering just returning your item as I didnt realise I would have so many issues (obviously I dont want to return it). Can anyone shed any light on this issue?
07-27-2018 05:39
07-27-2018 05:39
07-27-2018 05:42
07-27-2018 05:42
07-28-2018 17:28
07-28-2018 17:28
OMG! Dude, you solved it for me. I’ve spent hours trying to figure this out. After I read this post, I went in and changed my router settings to support 802.11 b/g/n (previously it was defaulted at 802.11 g/n). This did it. I would never have guessed! Thank you very much!
07-28-2018 21:13 - last edited on 07-31-2018 04:28 by JuanJoFitbit
That’s Exactly what happened to me. I had to reset Alexa and my printers and a bunch of other stuff. Nightmare
Moderator edit: format
07-30-2018 05:45 - last edited on 07-31-2018 04:33 by JuanJoFitbit
Apparently time-travel back to 1999 when b was released🙄 Bad call, Fitbit.
802.11b? B? I bought this scale in 2014- 15 years after b was released. It's now 2018 - 19 years after the release of b and we now have a new router thatis only backwards compatible to G, (which was released 15 years ago) and so the Aria no longer connects.
What kind of gadget company makes a decision to use technology that has been superceded by that much?
I'm certainly not buying another one in hopes you've "upgraded" all the way to g.
07-31-2018 04:42
07-31-2018 04:42
Hi everyone! I definitely understand how frustrating this is for you. Thank you so much for your feedback since this helps us to keep improving.
07-31-2018 09:24
07-31-2018 09:24
I’ve seen numerous post that the configurations are out of date. My Fitbit aria is still stuck with older configurations. I still have not been able to synced for 1 year. I did everything your systems configurations is out of date. I’ve heard that it hasn’t changed for a long time. If you have so many unhappy customers complaining of the same issues. I think it’s time to look into the configurations. I definitely will not he buying another scale.
08-02-2018 04:22
08-02-2018 04:22
@hopentyler Thank you for getting back and your comments! Since our team is reviewing this issue, I really appreciate your patience and time. We'll be happy to post a solution in this thread when available.
08-07-2018 22:00
08-07-2018 22:00
After struggling with this for nearly an hour, I found a solution to getting past the final step of the setup process: Do your setup close to your wifi access point.
08-07-2018 22:33
08-07-2018 22:33
Cheers for sharing that, I’m glad it worked for you. Unfortunately I already tried that. I’m switching to the Qardio scale - does more, great customer service and syncs with a blood pressure cuff that is medically recognised (I have severe hypotension 😊)
Cheers again,
Darsidhe
08-08-2018 05:26
08-08-2018 05:26
08-09-2018 08:35
08-09-2018 08:35
@PixelWrangler Welcome to our Fitbit forums! I'm glad to hear that your Aria scale could be connected. Thank you for sharing the workaround.
@Darsidhe @Jjthfuture I'm sorry to hear that your scales are still unable to connect. Your feedback is greatly appreciated.
08-09-2018 10:35
08-09-2018 10:35
08-10-2018 06:13
08-10-2018 06:13
This is absolutely ridiculous no one can get their scales to sync. You’re company still uses the older configuration. I am highly dissatisfied about your scale I can’t sync at all. This scale is useless. I will definitely will go to another’s company.
08-11-2018 04:34
08-11-2018 04:34
@KayakSkier @hopentyler I'm sorry to hear that your Aria kept showing the same error message. I understand your frustration about this and thank you so much for your feedback and comments.
08-12-2018 23:27
08-12-2018 23:27
My protocol is 802.11n, how do I change it to the protocol needed to sync my fit bit aria?
08-13-2018 03:36
08-13-2018 03:36
08-13-2018 08:17
08-13-2018 08:17
@Piramedic06 Thanks for participating in our Fitbit Community! I want to follow up on your case and would like to know if the issue persists or if your Aria could be connected to our WiFi.
@its_Tricky83 Your feedback is greatly appreciated and I'll make sure to send it to the rest of our team as it helps us to keep improving our products and services.
I'll be around if you guys have any questions!
08-13-2018 15:41 - last edited on 08-16-2018 08:06 by JuanJoFitbit
Hi, Juan,
I got your message re: removing my post stating that Fitbit’s usage of an already superceded technology from 1999 was a failure in development. If it was my obvious anger (though I used no inappropriate language) that violated the community guidelines, then you should be able to leave this one up so that the problem is clear.
If, however, the “violation” was to point out the clear failure on Fitbit’s part that is causing so many problems, then I guess you’ll delete this one, too, and we’ll learn something else about Fitbit’s learning procedures and respect for customers.
An okay idea but it shouldn’t be necessary to muck around with up to date tech because Fitbit decided to use tech that was already twice superceded when the Arias using it were released. They should offer to replace the scales with an upgraded scale, free of charge to anyone who experiences this foreseeable problem. Unless, ofcourse, the current version of the scale is still on B and this is happening to newly purchased scales, too - if that is the case, they should be offering full returns, and making it very clear on all the product info & packaging that it uses B so may not be compatible with most current Wifi routers.
Yours demurely,
Darcy
08-16-2018 08:16
08-16-2018 08:16
@Darsidhe I definitely understand your point and how you feel about this. Your feedback is well received as this helps us for improvement. I'll make sure to forward this info to our team.
