08-08-2015 18:00 - last edited on 09-10-2019 14:53 by MatthewFitbit
I have been trying to set up my scales. I go through almost the whole process until its trying to connect to WIFI and then a "WIFI ERR" shows up on the scales. I have checked my settings on my modem and it is on WPA2 PSK. I have also reset the modem more then once and tried the set up various times with no sucess. Does this have something to do with my modem? I have never had so many issues trying to set up one of my devices and I am considering just returning your item as I didnt realise I would have so many issues (obviously I dont want to return it). Can anyone shed any light on this issue?
03-27-2018 02:17 - edited 03-27-2018 19:04
Thank you!!!!!! You solved my problem I've had for over a year! I got a new XFinity router last year and the stupid scale never synced again until I followed your suggestion with a mobile hotspot. Now no problems!
What the suggestion was is to create a mobile hotspot (if your cell phone/provider allows it) and have the Aria go through setup with that network instead of your home network. You just have to turn on your hotspot everytime you want the Aria to sync so it uses your cell phone data plan.
My problem was, I guess, my XFinity router and even after changing it to allow a/b/g it didn't work. The hotspot solved my problem.
03-27-2018 07:36
03-27-2018 07:36
I didn’t see this suggestion. Can you give me some details as to how you solved this problem?
03-27-2018 13:37 - last edited on 08-11-2018 04:35 by JuanJoFitbit
I will have to say the amount of hours and months that I spent on this aria I almost threw it in the garbage. For anyone that is having problems, and you will shake your head in disbelief. 1) change the router to if you are able to 802.11mixed (n/g/b) ) name of your router/ modem if it has any numbers underscores or characters remove it. For an example apple1234 just name it apple. Setup your aria and voila it freaking works.
Moderator edit: format
03-27-2018 15:20
03-27-2018 15:20
03-27-2018 15:45
03-27-2018 15:45
03-27-2018 18:26
03-27-2018 18:26
I’m with you dayboyzpop! Mine lost sync again so I bought another brand. I say, give your Aria 1 to your ex as a parting gift.
03-27-2018 22:37
03-27-2018 22:37
Switching to mixed mode (802.11mixed (n/g/b) ) solved this for me. Thanks for the tip.
04-01-2018 21:37
04-01-2018 21:37
I've had my Aria scale 2 years this past February and loved it! Worked yesterday and ERR today. Batteries weren't dead, no router or wifi changes. Went through all troubleshooting with fitbit just to be told its defective and out of warranty. I've had $30 scales last longer than this. Disappointing for sure! It is connected to wifi but does the sensing, step off, thinking, ERR....
04-02-2018 14:53
04-02-2018 14:53
in my case number in SSID was the issue. I wasted 6 hrs. Aria firmware V39
04-10-2018 06:27
04-10-2018 06:27
Hi everyone! I really understand your frustration and know how you feel about the syncing issues that your Aria scales are experiencing. I would like you to take a look and follow the workaround that shared @prncssgeek in her post. If the issue persists, please let me know what is the make and model of your routers.
Hope to hearing from you soon guys!
04-13-2018 07:44
04-13-2018 07:44
I am having the same issues as others all of a sudden my Aria will not connect with my network.
I keep getting the WIFI ERR message even though it sees the wireless SSD name.
I am getting the wireless through my cable router.
The settings are controlled by the cable company.
All of my other devices are working fine only this scale.
I cannot change the setting to 802.11b.
What else can be done.
This is an old network setting how come Fitbit has not been updated to accept all.
This has been working fine for two years with the same router and configuration, now it won't connect.
04-14-2018 02:38
04-14-2018 02:38
Tried all the many suggestions re brain damaging the Router: naming, WPA2 v WEP v no security, reduction to 802.11b, removing account etc etc. The Aria is not Fit(Bit) for purpose! It is not worth the time and trouble. Mine is out of warranty in the UK so is effectively junk. My best option is probably to ignore all the tech fix nonsense and head to the small claims court. Do not buy one.
J
04-14-2018 03:53
04-14-2018 03:53
04-14-2018 07:32
04-14-2018 07:32
04-16-2018 05:37
04-16-2018 05:37
@djfred4 I noticed that you joined our Fitbit Community recently. Welcome aboard! I'm sorry to hear that your Aria scale has stopped connecting with your network. Please take a look at Kate's post since she mentioned an update about this issue. If you need help with the network changes, please get in touch with your Internet service provider so they can guide you step by step to change the protocol to 802.11 b/g/n.
Let me know if you have additional questions my friend!
04-16-2018 07:17
04-16-2018 07:17
04-16-2018 20:32
04-16-2018 20:32
Ditto!!! 4 hours and $ wasted
04-17-2018 06:06
04-17-2018 06:06
Re-configuring my entire network and every device for every user because this thing decided one day to stop connecting? That is not a solution. I spent $20 on a digital body fat scale on Amazon and tossed this brick in the trash where it belongs. My new $20 scale works perfectly, stores 10 users, measures more stats and now I just take the 2 seconds to manually log my weight into MFP.
04-17-2018 07:13
04-17-2018 07:13
04-17-2018 12:01
04-17-2018 12:01
I take it back!!! It worked initially, but then disconnected again
