04-24-2018 07:02 - last edited on 09-10-2019 14:53 by MatthewFitbit
Aria design issue
My aria scale is dropping wifi. Fitbit customer service says that it is a Comcast wifi problem. At my house we have 4 laptops, 2 printers and aria using the IEEE 802.11b 2.4 G. The aria scale is the ONLY one dropping off of wifi. Comcast sent a tech to my house - all equipment is working fine. FITBIT is saying that it is Comcast issue but Comcast is asking me do I have issues with other devices. There are none. FITBIT solution is for me to go to Comcast router WEB and reset IEEE 802.11b off of it's setting and reset back. This does works for one day. Then the aria drops wifi.
I believe the scale has a design issue and the FITBIT should replace my defective produce with one the works or give me a refund. FITBIT said I can purchase aria 2 (which I think does not have the issue) from them and get free shipping. I believe that the scale has a design issue and Fitbit would replace my produce or refund my money.
06-23-2018 09:04
06-23-2018 09:04
06-25-2018 08:39
06-25-2018 08:39
@momarbonz Thank you for letting me know more details about your router! Since you have a Comcast router, please keep an eye on this thread since an update will be posted in that thread when a solution is available.
Thank you for your patience with this!
06-25-2018 10:16 - edited 06-25-2018 10:41
This workaround seems to have only worked once.
So if an update to fix this becomes available & the Aria isn't able to connect VIA Wi-Fi, what the hell can you do?
Sent from my iPhone
06-26-2018 05:21
06-26-2018 05:21
@Nesto49 Regarding your question, I'll update the thread mentioned above and follow up in case your Aria is still unable to connect to your network.
07-15-2018 12:47
07-15-2018 12:47
07-15-2018 19:20
07-15-2018 19:20
07-16-2018 06:47
07-16-2018 06:47
Hi Juan,
What is “ACTIVELY” being done about this issue? It there a timeline for resolution? Can Fitbit just undue it’s last update until the is rectified?
I know in my field of work our IT department would never let an issue like this go unresolved. They would walk the update back until the bugs are worked out. How is this ok for a TECHNOLOGY company?
07-16-2018 08:27
07-16-2018 08:27
Agree! I will not buy anymore fitbit products!!
07-21-2018 06:09
07-21-2018 06:09
@momarbonz @pmnery @Chayla45 @Hifg I definitely understand how you feel about this issue and appreciate your feedback. We don't have a timeline about when a solution will be available. We'll make sure to post an update in this thread.
I appreciate your understanding!
10-12-2018 06:15
10-12-2018 06:15
I gave this months to be fixed. Just spent 30 minutes trying 3 different times. Obviously, FitBit doesn’t care about its existing customers. I have noticed that there are more versions of fitbits being marketed. I had my eye on the Versa but no thanks. I refuse to buy from a company that doesn’t care about the existing customers. More important to sell new fitbits and get the revenue from them.
10-12-2018 09:41
10-12-2018 09:41
They definitely do not care about existing users. We paid for the product and now they are done with us. This is not the only forum post about this particular issue. It would seem that this is a pattern for the company.
10-13-2018 20:21
10-13-2018 20:21
10-15-2018 07:32
10-15-2018 07:32
@momarbonz @scaleuser100 @Nesto49 I'm sorry to hear about the experience you've had with your Aria scales. Your feedback and comments are appreciated and were sent to our team.
10-15-2018 08:33
10-15-2018 08:33
10-15-2018 10:19 - last edited on 10-16-2018 09:24 by JuanJoFitbit
The only thing we will see is a few more messages from the mods every 2 months or so offering an empty promise that something will be done about this. If it could be done, it would be done. If they wanted it done, it would be done. There work concluded when we bought the scale, they do not stand behind their product.
Who on the team though? Are they receiving the literal last 2 years of this issue? If they are receiving are feedback why is it being ignored?
Moderator edit: format
10-16-2018 09:25
10-16-2018 09:25
@momarbonz @scaleuser100 Thank you for your feedback. We appreciate your patience and understanding with this.
11-08-2018 22:55 - last edited on 11-10-2018 08:48 by JuanJoFitbit
So the problem is not comcast. The problem is with the aria, it only supports 802.11 b. (ancient technology) so everybody blaming comcast because they improved there router and took out the 802.11b standard has got it wrong. Fitbit needs to come up with a firmware fix to allow newer standards.
Does the aria 2 still require the 802.11b also?
Its been almost a year since this problem has surfaced, however nothing from fitbit. come on. Do you really want to keep customers?
Maybe you should look into what the hell is wrong with your product.
Moderator edit: merged reply
11-10-2018 08:54
11-10-2018 08:54
@jodi.gaut We’re aware of the issue,
We understand that this isn't the resolution you were hoping for,
Regarding your question about the Aria 2, please check out this help article, which lists the router settings that the Aria 2 requires.
I'll be around if you have any doubts!
11-14-2018 09:42 - last edited on 11-17-2018 03:45 by JuanJoFitbit
If anyone at Fitbit has been getting paid to work on this solution it might be time to let them go. Its been years now. I am sure they were dedicated to their work but unfortunately they have not been able to produce reasonable results within an acceptable time frame. I do hope you wish them luck in the future.
I might actually buy another Fitbit product if they would just once own up to the fact that they made a poor product and did not have the courage to own that but are now trying to be a more responsive, transparent, and accountable company.
11-17-2018 03:49
11-17-2018 03:49
@scaleuser100 Thank you for sharing your thoughts.
