04-07-2018 08:48 - last edited on 09-10-2019 14:53 by MatthewFitbit
Group-
I have recently gotten an updated modeum form comcast. I have a fit bit ARIA scale.
The scale will not connect to the network because the protocals used by FItbit are outdated so I am not able to get the Aria scale to connect to the network and It no longer can track my weights and BF measurements which previously worked seemlessly. I have talked to Fit bit and Comcast with no solution. Comcast says that Fitbit needs to upgrade its protocals. They say this is a problem Fitbit is having with most new modeums. Does anyone have any ideas as to what I can do?
04-07-2018 09:07
04-07-2018 09:07
@kjgiac, you, or COMCAST, can easily change the settings on the WiFi router to enable the older protocol so that the scales will connect. COMCAST is taking the easy way out by point the finger elsewhere, but all routers are backward compatible with older protocols.
04-07-2018 09:13
04-07-2018 09:13
04-11-2018 06:44
04-11-2018 06:44
@kjgiac Welcome aboard to our Fitbit Community! I'd like you to take a look at Kate's post since she shared a workaround and an update for the syncing issue that you are experiencing with your Aria scale.
@USAF-Larry Thank you a lot for your constant help my friend!
See you both later!
04-15-2018 06:34
04-15-2018 06:34
No I did not get an answer to my query.
04-17-2018 04:16
04-17-2018 04:16
04-17-2018 09:45
04-17-2018 09:45
04-19-2018 06:19
04-19-2018 06:19
@kjgiac Thank you for letting me know your router details! Our team is already looking into this issue. There is no timeline for the fix. However, our team is actively working in order to have this issue fixed soon.
Let me know if you have any doubt my friend!
07-19-2018 05:01
07-19-2018 05:01
Have tried everything to connect with no success. I have wasted to much time and energy. Frustrated. Switching to Nokia body+ scale. I wanted convenience of weight tracked and logged. This is to much stress trying to connect to xfinity WiFi
07-26-2018 06:35 - edited 07-26-2018 06:36
@Ckuret Welcome to our Fitbit forums! I'm sorry to hear that you decided to use another brand. I definitely understand how you feel about this and I appreciate your feedback. This info will be sent to our team since this helps us to keep improving.
Let me know if you have any doubts!
01-05-2019 07:07
01-05-2019 07:07
Was a workaround ever figured out? And if so, can you please share step by step!
Thanks!
01-05-2019 07:11
01-05-2019 07:11
01-10-2019 03:43
01-10-2019 03:43
